Cannot find port when uploading sketch to board (UNO)
I have a sketch that uses the fastLED libary. I am trying to set all the LEDs in a certain patter and animate them. The problem appears when uploading the sketch. When I go to uploading the sketch I get this error and the UNO dissapears from the port menu.
Sketch uses 5834 bytes (18%) of program storage space. Maximum is 32256 bytes.
Global variables use 1042 bytes (50%) of dynamic memory, leaving 1006 bytes for local variables. Maximum is 2048 bytes.
/private/var/folders/7t/592nw3054xqb3c05ylm_gvb40000gn/T/AppTranslocation/9C9A32ED-3DB1-4114-907F-8FFD15195A97/d/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/private/var/folders/7t/592nw3054xqb3c05ylm_gvb40000gn/T/AppTranslocation/9C9A32ED-3DB1-4114-907F-8FFD15195A97/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem141401 -b115200 -D -Uflash:w:/var/folders/7t/592nw3054xqb3c05ylm_gvb40000gn/T/arduino_build_317003/ledmatrixtest.ino.hex:i
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/private/var/folders/7t/592nw3054xqb3c05ylm_gvb40000gn/T/AppTranslocation/9C9A32ED-3DB1-4114-907F-8FFD15195A97/d/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/u6077250/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/cu.usbmodem141401
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "/dev/cu.usbmodem141401": No such file or directory
avrdude done.  Thank you.
Problem uploading to board.  See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
I tried this on the original arduino and also on the rev3 and they both give me the same problem. I am on a mac have tried it on 2 macs at the moment. Here is the sketch of the whole thing:
#define FASTLED_INTERNAL
    #include <FastLED.h>
    #define NUM_LEDS 256
    #define DATA_PIN 6
    #define MATRIX_WIDTH 32
    #define MATRIX_HEIGHT 8
CRGB leds[NUM_LEDS];
  FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
  FastLED.setBrightness(50);
  pinMode(LED_BUILTIN, OUTPUT);
int translateToDin (int x, int y) {
  if(x%2 == 0) {
    return (8 * x)  + y;
    return (8 * x)  + (8-y-1);
int randled = 0;
void putInBuffer(int position, CRGB matrix[8][8], int row, int column) {
  for(int i = 0; i<row;i++) {
    for(int j = 0; j<column;j++) {
      leds[translateToDin(i+position,j)] = matrix[j][i];
int looper = 0;
//            leds[0] = CRGB::Blue;
//            leds[1] = CRGB::Red;
//            leds[2] = CRGB::Yellow;
//            leds[3] = CRGB::Black;
//            leds[4] = CRGB::Orange;
//            leds[5] = CRGB::White;
//need to specify a matrix in a grid
//need a way to move the matrix in the whole buffer
            CRGB yellowblack[8][8] = {
              {CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Yellow}
            CRGB redyellow[8][8] = {
              {CRGB::Red,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Red,CRGB::Red,CRGB::Red},
              {CRGB::Red,CRGB::Red,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Red,CRGB::Red},
              {CRGB::Red,CRGB::Red,CRGB::Red,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Red},
              {CRGB::Red,CRGB::Red,CRGB::Red,CRGB::Red,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow,CRGB::Yellow},
              {CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black, CRGB::Black}
            putInBuffer(looper,redyellow,8,8);
            putInBuffer(looper + 8,redyellow,8,8);
            putInBuffer(looper + 16,redyellow,8,8);
            putInBuffer(looper + 24,redyellow,8,8);
            FastLED.show();
            //delay(3000);
  randled++;
//  looper++;
//  if(looper==8) {
//    looper = 0;
The problem usually happens when I uncomment the 5 lines at the bottom on the sketch. I cant figure out what could cause this.
No way. This has nothing with a sketch. It can be something with OS, access to the port or such trivial problem like broken cable.
I know that is what is confusing me. It makes no sense for the sketch to behave this way. I have tried another cable and got the same results. I have tried different laptops, cables and different arduino boards. What else can it be? I even tried a powered usb hub instead of a regular usb hub
Fascinating. Looks as if your buffer is overrunning and upsetting the arduino's USB connectivity.
I have had a similar issue after allowing an array to over run .
Maybe a power issue ( supplying Leds) ? Will it up load with them disconnected ?
Best to go back to basics and see if blink will upload to identify the problem area
