Cannot find the error, the received data is not clear, Doesn't turn on XBee
this code receives a data from server(I tested the received data with UDPSENDRECEIVESTRING, it has no problem)
the received data is something like this "No1;No2;No3;No4;No5:01"
the code should change digital pins on XBee(s) with ID=No1,No2...
And based on 00 or 10 or 01 ... at the end of the received data it should decide to change the pin D1 or D3 or turn off all the XBee in the network. (as it is shown in the code)
but it doesn't work and turns some XBee(s) randomly!!!
can anyone find the problem please?
Here is the code(because the question became too long I had to delete extra void functions at the end)
#include <Ethernet2.h> //Load Ethernet Library
#include <EthernetUdp2.h> //Load UDP Library
#include <SPI.h> //Load the SPI Library
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE}; //Assign a mac address
IPAddress ip(192, 168, 100, 90); //Assign my IP adress
unsigned int localPort = 5555; //Assign a Port to talk over
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
String MsgData; //String for our data
int packetSize; //Size of Packet
EthernetUDP Udp; //Define UDP Object
Serial.begin(9600); //Turn on Serial Port
Ethernet.begin(mac, ip); //Initialize Ethernet
Udp.begin(localPort); //Initialize Udp
delay(1500); //delay
  packetSize = Udp.parsePacket(); //Read theh packetSize
  if(packetSize>0)  { //Check to see if a request is present
  Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE); //Reading the data request on the Udp
  String MsgData(packetBuffer); //Convert packetBuffer array to string datReq
  Serial.println(MsgData);
  int No1 = MsgData.indexOf("No1");
  int No2 = MsgData.indexOf("No2");
  int No3 = MsgData.indexOf("No3");
  int No4 = MsgData.indexOf("No4");
  int No5 = MsgData.indexOf("No5");
  int cri = MsgData.indexOf("00");
  int med = MsgData.indexOf("01");
  int m20 = MsgData.indexOf("10");
  int m40 = MsgData.indexOf("20");
  int m60 = MsgData.indexOf("60");
  int reset = MsgData.indexOf("40");
  while (reset >= 0){
    OffAllAlarm(0x4);
    OffAllLight(0x4);
  while ((cri >= 0) || (med >= 0))
  if(No1 >= 0)
    Alarm1(0x5);
  if(No2 >= 0)
    Alarm2(0x5);
  if(No3 >= 0)
    Alarm3(0x5);
  if(No4 >= 0)
    Alarm4(0x5);
  if(No5 >= 0)
    Alarm5(0x5);
  delay(10000);
    Alarm1(0x4);
    Alarm2(0x4);
    Alarm3(0x4);
    Alarm4(0x4);
    Alarm5(0x4);
  while ((m20 >= 0) || (m40 >= 0) || (m60 >= 0))
    if(No1 >= 0)
    Light1(0x5);
  if(No2 >= 0)
    Light2(0x5);
  if(No3 >= 0)
    Light3(0x5);
  if(No4 >= 0)
    Light4(0x5);
  if(No5 >= 0)
    Light5(0x5);
  delay(10000);
    Light1(0x4);
    Light2(0x4);
    Light3(0x4);
    Light4(0x4);
    Light5(0x4);
  memset(packetBuffer, 0, UDP_TX_PACKET_MAX_SIZE);
void OffAllAlarm(char value){
 Serial.write(0x7E);    //sync byte
 Serial.write(0x00);    //length
 Serial.write(0x10);
 Serial.write(0x17);    //command type, 17 is AT
 Serial.write(0x00);    //command sequence number(???)
 Serial.write(0x00);    //destination serial number (64bit)
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0xFF);
 Serial.write(0xFF);
 Serial.write(0xFF);    //destination network address(???)
 Serial.write(0xFE);
 Serial.write(0x02);    //remote command options(???)
 Serial.write('D');    //ASCII command name!!!
 Serial.write('1');
 Serial.write(value);    //command
 long sum = 0x17 + (0x00 + 0x13 + 0xA2 + 0x00 + 0x40 + 0xE4 + 0x2D + 0xC0) + 0xFF + 0xFE + 0x02 + 'D' + '1' + value;
 Serial.write(0xFF - (sum & 0xFF));    //checksum from byte4 to previous one
void OffAllLight(char value){
 Serial.write(0x10);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0x00);
 Serial.write(0xFF);
 Serial.write(0xFF);
 Serial.write(0xFE);
 Serial.write('3');
void Alarm1(char value){
 Serial.write(0x10);
 Serial.write(0x13);
 Serial.write(0xA2);
 Serial.write(0x00);
 Serial.write(0x40);
 Serial.write(0xE4);
 Serial.write(0x2D);
 Serial.write(0xC0);
 Serial.write(0xFE);
 Serial.write('1');
 void Alarm2(char value){
void Alarm3(char value){
void Alarm4(char value){
void Alarm5(char value){
void Light1(char value){
 Serial.write(0x10);
 Serial.write(0x13);
 Serial.write(0xA2);
 Serial.write(0x00);
 Serial.write(0x40);
 Serial.write(0xE4);
 Serial.write(0x2D);
 Serial.write(0xC0);
 Serial.write(0xFE);
 Serial.write('3');
 long sum = 0x17 + (0x00 + 0x13 + 0xA2 + 0x00 + 0x40 + 0xC2 + 0x7D + 0xBF) + 0xFF + 0xFE + 0x02 + 'D' + '3' + value;
void Light2(char value){
void Light3(char value){
void Light4(char value){
void Light5(char value){
The buffer is NOT NULL terminated. It should, therefore, NOT be passed to a functiont hat expects a string.
As a result of passing crap to the String constructor, MsgData is a load of crap.
  while (reset >= 0){
    OffAllAlarm(0x4);
    OffAllLight(0x4);
That looks pretty silly. Why would you use a while statement when the condition never changes in the body of the while loop?
None of your while loops make any sense. They should ALL be if statements. If and while are NOT interchangeable.
