Continuing the discussion from Nano Every issues:
I installed MegaCoreX and my code compiles and uploads with no errors but I cannot get the TFMini Lidar sensor to show anything in serial monitor. I'm using the USB cable to power the Nano Every.
#include <SoftwareSerial.h> //header file of software serial port
SoftwareSerial Serial5(2, 3); //define software serial port name as Serial5 and define pin2 as RX (white) & pin3 (green) as TX
int dist; //actual distance measurements of LiDAR
int strength; //signal strength of LiDAR
int check; //save check value
int i;
int uart[9]; //save data measured by LiDAR
const int HEADER = 0x59; //frame header of data package
// Define the pins for the LEDs
const int greenLED = 8;
const int redLED = 12;
Serial.begin(9600); //set bit rate of serial port connecting Arduino with computer
Serial5.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
// Initialize the LED pins as outputs
pinMode(greenLED, OUTPUT);
pinMode(redLED, OUTPUT);
if (Serial5.available()) //check if serial port has data input
if (Serial5.read() == HEADER) //assess data package frame header 0x59
uart[0] = HEADER;
uart[1] = HEADER;
for (i = 2; i < 9; i++) //save data in array
uart[i] = Serial5.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)) //verify the received data as per protocol
dist = uart[2] + uart[3] * 256; //calculate distance value
strength = uart[4] + uart[5] * 256; //calculate signal strength value
Serial.print("distance = ");
Serial.print(dist); //output measure distance value of LiDAR
Serial.print('\t');
//delay(500);
Serial.print("strength = ");
Serial.print(strength); //output signal strength value
Serial.print('\n');
// Control the LEDs based on the distance
if(dist < 15)
//Light the red LED
digitalWrite(redLED, HIGH);
digitalWrite(greenLED, LOW);
else if (dist >= 16 && dist <= 76)
// Light the green LED
digitalWrite(greenLED, HIGH);
digitalWrite(redLED, LOW);
//else if (dist >= 31 && dist <= 76)
//digitalWrite(greenLED, HIGH);
//digitalWrite(redLED, LOW);
else if (dist > 76)
// Light the red LED
// Turn off all LEDs if the distance is not within any range
