I can't install the Arduino Create Agent on macOS.
The file downloads and I can open it. When it starts installing I get the message "ArduiniCreateAgent.app is damaged and cannot be opened. Move to the bin". When I click cancel to seems that de installation finishes, but in de browser the agent is sever found.
I looked it up and there was a similar tread in 2021 but no solution...
I'm glad it is working now. Thanks for taking the time to post an update with your findings!
If you would like, you can mark the topic as "solved":
At the bottom of each reply to a topic you created, you will see a "☑ Solution" control:
Find the post that contains the solution and click on "☑ Solution". You will now see it change to the active state:
A checkmark will be shown next to the title in the topic listings. For example:
A preview of the solution will be added to the first post. For example:
Marking the solution is helpful because it allows those with the same question to more quickly find the answer, and allows the helpers on the forum to differentiate solved topics from the ones that still require their assistance.
