I am working in my quadcopter. Right now I am just testing for take- off and Roll angle. I tried to integrate PID library in my code but it keeps generating 100 and my quadcopter goes blasting. Right now I am just giving 1,1,1 for kp,ki and kd. I know this is not right but like I said, I am just playing. Here is my Code. ..
#define CHNL_HIGH 1900
#define CHNL_LOW 1100
#define THROTTLE_CHNL 2
#define CW1_IN 9
#define CW2_IN 10
#define CW3_IN 11
#define CW4_IN 12
#define ARM_DEG 21
#define THROTTLE_FLAG 1
Servo servoCW1;
Servo servoCW2;
Servo servoCW3;
Servo servoCW4;
int servoCW1_DEG = 0;
int servoCW2_DEG = 0;
volatile uint8_t bUpdateFlagsShared;
volatile uint16_t unThrottleInShared;
volatile int throttleOffset;
uint32_t ulThrottleStart;
float ypr[3]; // yaw pitch roll
//Define Variables we'll be connecting to
double Input_roll,rollOffset,Setpoint_roll;
PID myPID(&Input_roll, &rollOffset, &Setpoint_roll,1,1,1, DIRECT);
// Set the FreeIMU object
FreeIMU my3IMU = FreeIMU();
Wire.begin();
delay(5);
my3IMU.init(); // the parameter enable or disable fast mode
//initialize the variables we're linked to
Setpoint_roll = -5.00;
//turn the PID on
myPID.SetMode(AUTOMATIC);
myPID.SetOutputLimits(-100.00, 100.00);
servoCW1.attach(CW1_IN);
servoCW2.attach(CW2_IN);
servoCW3.attach(CW3_IN);
servoCW4.attach(CW4_IN);
Serial.println("GET IT");
arm();
attachInterrupt(0, calcThrottle,CHANGE);
delay(5);
static uint16_t unThrottleIn;
static uint8_t bUpdateFlags;
// check shared update flags to see if any channels have a new signal
if(bUpdateFlagsShared)
noInterrupts();
bUpdateFlags = bUpdateFlagsShared;
if(bUpdateFlags & THROTTLE_FLAG)
unThrottleIn = unThrottleInShared;
bUpdateFlagsShared = 0;
interrupts(); // we have local copies of the inputs, so now we can turn interrupts back on
throttleChange(unThrottleIn);
my3IMU.getYawPitchRoll(ypr);
Input_roll = ypr[2];
myPID.Compute();
rollChange(rollOffset);
bUpdateFlags = 0;
void rollChange(double rollOffset)
int valCW1 = servoCW1.readMicroseconds();
int valCW2 = servoCW2.readMicroseconds();
Serial.print("offset: ");
Serial.println(rollOffset);
valCW1 = valCW1 + rollOffset;
valCW2 = valCW2 - rollOffset;
Serial.print("valCW1: ");
Serial.println(valCW1);
Serial.print("valCW2: ");
Serial.println(valCW2);
Serial.println("");
Serial.println("");
servoCW1.writeMicroseconds((int)valCW1);
servoCW2.writeMicroseconds((int)valCW2);
void arm()
servoCW1.write(ARM_DEG);
servoCW2.write(ARM_DEG);
servoCW3.write(ARM_DEG);
servoCW4.write(ARM_DEG);
void throttleChange(int cha_val)
servoCW1.writeMicroseconds(cha_val);
servoCW2.writeMicroseconds(cha_val);
servoCW3.writeMicroseconds(cha_val);
servoCW4.writeMicroseconds(cha_val);
void calcThrottle()
if(digitalRead(THROTTLE_CHNL) == HIGH)
ulThrottleStart = micros();
}else
unThrottleInShared = (uint16_t)(micros() - ulThrottleStart);
bUpdateFlagsShared |= THROTTLE_FLAG;
I am getting an rollOffset from the PID controller. And action is taken in the rollchange() function. My setpoint is -5.00.
Problem: The PID outputs 100 most of the time. And, I don't think it is helping to reach my setpoint but it is really destroying it. So my question is am I really using the output from PID the right way.
