New-bought pro-mini and Sparkfun FTDI Basic
Attempt to upload simple sketch,
int aLed = 6;
int bLed = 5;
pinMode(aLed, OUTPUT);
pinMode(bLed, OUTPUT);
digitalWrite(aLed, HIGH);
delay(2000);
digitalWrite(bLed, HIGH);
digitalWrite(aLed, LOW);
delay(3000);
delay(2000);
digitalWrite(bLed, LOW);
delay(2000);
Error messages in response to "Upload":
Arduino: 1.8.14 Hourly Build 2021/01/29 11:33 (Windows 10), Board: "Arduino Pro or Pro Mini, ATmega328P (5V, 16 MHz)"
Sketch uses 1012 bytes (3%) of program storage space. Maximum is 30720 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Users\tom\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\tom\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM10 -b57600 -D -Uflash:w:C:\Users\tom\AppData\Local\Temp\arduino_build_430315/MINI-Pro_light_LEDs.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\tom\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
avrdude: can't open config file "C:\Users\tom\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf": No such file or directory
avrdude: error reading system wide configuration file "C:\Users\tom\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Invalid library found in C:\Users\tom\Documents\Arduino\libraries\arduino: Missing 'author' from library
Invalid library found in C:\Users\tom\Documents\Arduino\libraries\processing-latest: no headers files (.h) found in C:\Users\tom\Documents\Arduino\libraries\processing-latest
option enabled in File -> Preferences.
In the IDE "Board" is specified as pro mini, and I reconfig'd the port (Windows Device Manager) by checking "Set RTS on Close"
No preferences changed, except to get verbose messages for upload.
