cannot load sketches when wave shield is attached
hello all I am trying to get thewave shield from adafruit to work butwhen I try and load any sketch that works when the wave shield is not installed I get the not detected error with wave shield attached here is a sample of coding that will run without but not with the wave shield the error I get from the compiler :avrdude: stk500_getsync(): not in sync: resp=0x00 its like windows doesnt see the device anymore.
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the filesystem on the card
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
// Function definitions (we define them here, but the code is below)
void lsR(FatReader &d);
void play(FatReader &dir);
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
  putstring_nl("\nWave test!");  // say we woke up!
  putstring("Free RAM: ");       // This can help with debugging, running out of RAM is bad
  Serial.println(freeRam());
  // Set the output pins for the DAC control. This pins are defined in the library
  pinMode(2, OUTPUT);
  pinMode(3, OUTPUT);
  pinMode(4, OUTPUT);
  pinMode(5, OUTPUT);
  //  if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    putstring_nl("Card init. failed!");  // Something went wrong, lets print out why
    sdErrorCheck();
    while(1);                            // then 'halt' - do nothing!
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {     // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                             // we found one, lets bail
  if (part == 5) {                       // if we ended up not finding one  :(
    putstring_nl("No valid FAT partition!");
    sdErrorCheck();      // Something went wrong, lets print out why
  // Lets tell the user about what we found
  putstring("Using partition ");
  Serial.print(part, DEC);
  putstring(", type is FAT");
  Serial.println(vol.fatType(),DEC);     // FAT16 or FAT32?
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    putstring_nl("Can't open root dir!"); // Something went wrong,
  // Whew! We got past the tough parts.
  putstring_nl("Files found:");
  dirLevel = 0;
  // Print out all of the files in all the directories.
  lsR(root);
//////////////////////////////////// LOOP
  root.rewind();
  play(root);
/////////////////////////////////// HELPERS
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
  extern int  __bss_end;
  extern int  *__brkval;
  int free_memory;
  if((int)__brkval == 0) {
    free_memory = ((int)&free_memory) - ((int)&__bss_end);
  else {
    free_memory = ((int)&free_memory) - ((int)__brkval);
  return free_memory;
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void)
  if (!card.errorCode()) return;
  putstring("\n\rSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  putstring(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * print dir_t name field. The output is 8.3 format, so like SOUND.WAV or FILENAME.DAT
void printName(dir_t &dir)
  for (uint8_t i = 0; i < 11; i++) {     // 8.3 format has 8+3 = 11 letters in it
    if (dir.name[i] == ' ')
        continue;         // dont print any spaces in the name
    if (i == 8)
        Serial.print('.');           // after the 8th letter, place a dot
    Serial.print(dir.name[i]);      // print the n'th digit
  if (DIR_IS_SUBDIR(dir))
    Serial.print('/');       // directories get a / at the end
 * list recursively - possible stack overflow if subdirectories too nested
  int8_t r;                     // indicates the level of recursion
  while ((r = d.readDir(dirBuf)) > 0) {     // read the next file in the directory
    // skip subdirs . and ..
    if (dirBuf.name[0] == '.')
      continue;
    for (uint8_t i = 0; i < dirLevel; i++)
      Serial.print(' ');        // this is for prettyprinting, put spaces in front
    printName(dirBuf);          // print the name of the file we just found
    Serial.println();           // and a new line
    if (DIR_IS_SUBDIR(dirBuf)) {   // we will recurse on any direcory
      FatReader s;                 // make a new directory object to hold information
      dirLevel += 2;               // indent 2 spaces for future prints
      if (s.open(vol, dirBuf))
        lsR(s);                    // list all the files in this directory now!
      dirLevel -=2;                // remove the extra indentation
  sdErrorCheck();                  // are we doign OK?
 * play recursively - possible stack overflow if subdirectories too nested
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // skip . and .. directories
      continue;
    Serial.println();            // clear out a new line
    if (!file.open(vol, dirBuf)) {       // open the file in the directory
      Serial.println("file.open failed");  // something went wrong :(
      while(1);                            // halt
    if (file.isDir()) {                    // check if we opened a new directory
      putstring("Subdir: ");
      printName(dirBuf);
      dirLevel += 2;                       // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing "); printName(dirBuf);       // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
        Serial.println();                  // Hooray it IS a WAV proper!
        wave.play();                       // make some noise!
        while (wave.isplaying) {           // playing occurs in interrupts, so we print dots in realtime
          putstring(".");
          delay(100);
        sdErrorCheck();                    // everything OK?
//        if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
Please read the how to use the forum sticky post and post your code here.
What is giving these errors, the compiler or the software in the arduino you are running?
Do the standard wave shield examples work?
I just looked in devices and printers and notice the arduino itself it not detected when the wave shield is installed, so it looks like I have a different issue altogether
Check the pins round pins 0 & 1 for shorts.
It could also be taking the power supply down so look at the voltage on the 5V pin with and without the shield.
