cannot measure frequency with FreqMeasure.h library arduino 101 Curie
i am working with a project which is about heart beat measurement with arduino. That is why i have to measure the frequency from my lm324n op-amp. i am using FreqMeasure.h library for measuring the frequency but I get a error. does Arduino 101 not support this library? do i need to do some changes to let it work?
#include <FreqMeasure.h>
Serial.begin(57600);
FreqMeasure.begin();
double sum=0;
int count=0;
float frequency;
if (FreqMeasure.available()) {
// average several reading together
sum = sum + FreqMeasure.read();
count = count + 1;
if (count > 30) {
double frequency = F_CPU / (sum / count);
Serial.println(frequency);
sum = 0;
count = 0;
So, where's that error of yours?
Also, please edit you post to have code-tags. See How to use the forum please.
Of course you do. The FreqMeasure library is NOT portable. It works for a very limited number of Arduinos.
thanks for your reply
I was already thinking this library was not made for the intel 101 board. Is there a easy way to measure accurate time between 2 pulse on the 101?
That depends on the interval between the pulses. If they are a week apart, measuring the time to +/- 1 day is trivial. To +/- 1 millisecond isn't much more challenging.
If the frequency is more than once every 4 microseconds, then it becomes more challenging. You have to count a number of pulses, then divide by the time you did nothing but read pulses.
Thanks for your help,
I found this code.
will try with this one
volatile byte count = 0;
byte numCount = 8; //number of pulse intervals to measure
volatile unsigned long startTime;
volatile unsigned long endTime;
unsigned long copy_startTime;
unsigned long copy_endTime;
volatile boolean finishCount = false;
float period;
unsigned int rpm = 0;
Serial.println(“start…”);
//pinMode(2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(2), isrCount, RISING);//interrupt on pin2
if (finishCount == true)
finishCount = false;//reset flag
// disable interrupts, make protected copy of time values
noInterrupts();
copy_startTime = startTime;
copy_endTime = endTime;
count = 0;
interrupts();
period = (copy_endTime - copy_startTime) / 1000.0; //micros to millis
//debug prints
Serial.print(period); //total time for numCount
Serial.print(’\t’);
Serial.println(period/numCount);//time between individual pulses
//rpm = numCount * 60.0 * (1000.0 / period);//one count per revolution
rpm = numCount * 30.0 * (1000.0 / period);//two counts per revolution
Serial.print("RPM = ");
Serial.println(rpm);
void isrCount()
if (count == 0)//first entry to isr
startTime = micros();
if (count == numCount)
endTime = micros();
finishCount = true;
count++; //increment after test for numCount
