When I am working on an IOT sketch and want to modify a custom library, the WEB frontend freezes and the library does not load.
When I am working on a "non-IOT" sketch, I can modify my custom library.
Although I have a service request open, I post this issue here, b/c I have the impression, that the 1st level support does not understand my problem (asking why I would change a library in the cloud ...).
Do you mean using the web version of the IDE and using a "standard" library in your code ?
How is the "custom library" referred to and where do you modify it?
Hello,
please see attached video files. I am working with the IOT Cloud Editor.
When I made the screen capture, the Arduino Create Agent was not running - hence the message - but this does not make a difference.
I also include the zip file of the library. It does work in the cloud and in the IDE on my machine. However, I use several machines and don’t want to store these files locally in order to avoid effort for backup and sync. Once created locally the original should rest in the cloud and I want to be able to modify them there. Of course I can always edit them with a dummy not IOT sketch, but this workaround is cumbersome
Kind regards
Guenter
LED.zip (1.68 KB)
(Attachment IOT-Sketch_540.mp4 is missing)
(Attachment Sketch_without_Thing_540.mp4 is missing)
Hello,
I also include the zip file of the library. It does work in the cloud and in the IDE on my machine. However, I use several machines and don’t want to store these files locally in order to avoid effort for backup and sync. Once created locally the original should rest in the cloud and I want to be able to modify them there. Of course I can always edit them via a dummy non-IOT sketch, but this workaround is cumbersome.
Kind regards
Guenter
I'l not downloading any zip stuff to my Mac.
put your video on youTube and paste the link directly into the forum
is you post code, do it here as well, making sure you use code tags.
Sorry for trying to send you video files and zip files. Interestingly enough I was asked from 1st level support to do so in the context of another problem ![]()
I posted two videos on youtube:
non IOT sketch
With the IOT sketch I can wait for hours - the library won't load.
feels like a bug indeed
Hi @ghu-01. Thanks for your report. I can reproduce the fault and have submitted a formal bug report to the Arduino Cloud developers.
I'll post an update here if I receive any news from the developers about a resolution.
Until then, please continue to use the workaround you found when you need to modify the library.
Hello again @ghu-01. I'm happy to report that the Arduino Cloud developers have fixed the bug.
I apologize for any inconvenience this has caused.
Please give it a try and let us know if you still have any problems,
Thanks again for bringing this to our attention!
Hello, thank you very much. It works now!
Regards Guenter
You are welcome. Thanks for taking the time to share your results!
Regards,
Per
