Cannot open a file from SD when using multiple loops [SOLVED]
Robin2:
Sorry, but I can't see anything that might be causing the problem, but I don't have your hardware so I can't do any tests.
In the program that is in Reply #16 try adding these few extra lines into the keypadInput() function
void keypadInput() {
if (coinsValue < 1) {                                // new piece
      Serial.println("not enough money");
      return;
//pressing the key -> assigning the filename
  char customKey = myKeypad.waitForKey();
if (customKey != NO_KEY)
Another diagnostic approach is to try this, without any keypadInput()
// if coins value is enough to make a call - dial
  if (coinsValue >= 1)
    lcd.setCursor (7, 0);      // go to start of 2nd line
    lcd.print("Skambink!");
    playSound("test.wav");
It would be much better if you separated the keypadInput() code into two functions. One that reads the keypad and saves the value and another that checks that saved value and plays the sound. That way you can test the two parts separately.
...R
Thanks for the help - with a lot of help from you and geeks at the lab I have found the solution!
The program works as intended - for now.
  1. char waitForKey() blocks everything. It unusable in this (and many other) scenarios. I've managed to apply char getKey() for the same purpose.
  2. My power source was corrupted - extra ground was needed, all-ok now.
  3. Interrupt cable was connected to 10th pin - same as my SD card chipselect pin, now 19th.
Program works as follows:
  1. Insert 1€ or more into the coin acceptor.
  2. Lcd shows you inserted amount, and informs you when 1€ is reached ("Skambink!")
  3. Dial a number (1441, 2552 or 3663).
  4. Hear a sound e.g. jonas.wav/petras.wav/antanas.wav
I will be adding language select buttons (A,B,C,D) and some millis() to not be stuck accidentally in one of the loops.
volatile float coinsValue = -0.10;
//Interrupt pin works somewhat difficult on DUE - sends a signal when DUE turns on, I offset value by one step
int coinsChange = 0;
//A Coin has been inserted flag
#include <Wire.h>
#include <LCD.h>
#include <DAC.h>
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
#include <Key.h>
#include <Keypad.h>
#define I2C_ADDR    0x3F // Add your address here.  Find it from I2C Scanner
#define BACKLIGHT_PIN     3
#define En_pin  2
#define Rw_pin  1
#define Rs_pin  0
#define D4_pin  4
#define D5_pin  5
#define D6_pin  6
#define D7_pin  7
LiquidCrystal_I2C  lcd(I2C_ADDR, En_pin, Rw_pin, Rs_pin, D4_pin, D5_pin, D6_pin, D7_pin);
const byte ROWS = 4;
const byte COLS = 4;
int code1 = 1441;  //The code I used, you can change it
int code2 = 2552;  //The code I used, you can change it
int code3 = 3663;  //The code I used, you can change it
int tot, i1, i2, i3, i4;
char c1, c2, c3, c4;
char hexaKeys[ROWS][COLS] = {
  {'1', '2', '3', 'A'},
  {'4', '5', '6', 'B'},
  {'7', '8', '9', 'C'},
  {'*', '0', '#', 'D'}
byte rowPins[ROWS] = {9, 8, 7, 6};
byte colPins[COLS] = {5, 4, 3, 2};
int keyCounter = 0;
Keypad myKeypad = Keypad(makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
  // debug output at 9600 baud
  //My LCD is 16x2
  lcd.begin (16, 2);
  SD.begin(10);
  //for DUE - any digital pin as Interrupt pin
  attachInterrupt(digitalPinToInterrupt(19), coinInserted, RISING);
  // Switch on the backlight
  lcd.setBacklightPin(BACKLIGHT_PIN, POSITIVE);
  lcd.setBacklight(HIGH);
  lcd.home (); // go home
  lcd.print("Suma:");
void coinInserted()
//The function that is called every time it recieves a pulse
  coinsValue = coinsValue + 0.10;
  //As we set the Pulse to represent 5p or 5c we add this to the coinsValue
  coinsChange = 1;
  //Flag that there has been a coin inserted
char keypresses[4];
  if (coinsChange == 1)
    //Check if a coin has been Inserted
    coinsChange = 0;
    //unflag that a coin has been inserted
  lcd.setCursor (0, 1);       // go to start of 2nd line
  //Print the Value of coins inserted
  lcd.print(coinsValue);
  Serial.println(coinsValue);
    lcd.setCursor (7, 1);       // go to start of 2nd line
    Serial.println("Skambink!");
    keypadInput();
  //getting the key when button is pressed instead of waitForKey
  char customKey = myKeypad.getKey();
  if (NO_KEY != customKey) {
    //storing number into array
    keypresses[keyCounter] = customKey;
    //counting how many number we've got
    keyCounter++;
    Serial.print(customKey);
  //if we have 4 numbers - proceed
  if (keyCounter > 3)
    keyCounter = 0;
    //the keys pressed are stored into chars I convert them to int then i did some multiplication to get the code as an int of xxxx
    i1 = (keypresses[0] - 48) * 1000;
    i2 = (keypresses[1] - 48) * 100;
    i3 = (keypresses[2] - 48) * 10;
    i4 = keypresses[3] - 48;
    tot = i1 + i2 + i3 + i4;
    if (tot == code1) //if the code is correct you trigger to play .wav
      playSound("jonas.wav");
    else if (tot == code2)
      playSound("petras.wav");
    else if (tot == code3)
      playSound("antanas.wav");
    else if (tot == 0000)
    else //if the code is wrong you get another thing
      for (int j = 0; j < 256; j++) {
        for (int i = 0; i < 256; i++)
          analogWrite(DAC1, i);
      playSound("blogas.wav");
// Playing assigned filename
void playSound(const char* cName) {
  File myFile = SD.open(cName);
  const int S = 1024; // Number of samples to read in block
  short buffer[S];
  // until the file is not finished
  Serial.println("playing ");
  Serial.println(cName);
  Audio.begin(44100, 100);
  while (myFile.available()) {
    myFile.read(buffer, sizeof(buffer));
    // Prepare samples
    int volume = 1024;
    Audio.prepare(buffer, S, volume);
    Audio.write(buffer, S);
  Audio.end();
  myFile.close();
