Cannot pass FlashStringHelper string from F macro to called routine.
On version 1.8.4 of the Arduino IDE on Windows 10.
Here’s a stripped out sample of my problem. I saw an answer to this same problem that gave the solution I am using here. That answer is:
I do see that your snippet has the __FlashStringHelper error. This is because the output of the F() function is a (char const *) and your definition it is a (char *). Hence the miss-match.
It does not work for me, still giving:
cannot convert ‘const __FlashStringHelper*’ to ‘const char*’ for argument ‘1’ to ‘void AppendAndSendHTML(const char*, bool, bool)’
void setup() { }
void AppendAndSendHTML(char const * HTML, bool initial = false, bool final = false)
  AppendAndSendHTML(F("HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n"), true, false);
That's an incorrect answer. You need to do this:
void AppendAndSendHTML(const __FlashStringHelper* HTML, bool initial = false, bool final = false)
