I have to post data to the webserver on WAMP using arduino wifi shield.The shield connects well to the server but cannot post the data in the sql database running on the server code is below.
#include <TinkerKit.h>
#include <WiFi.h>
#include <SPI.h>
char ssid[] = "mokete"; // your network SSID (name)
char pass[] = "59654125"; // your network password
int status = WL_IDLE_STATUS;
//WiFiServer server(80);
long previousMillis = 0;
unsigned long currentMillis = 0;
long interval = 250000; // READING INTERVAL
int sensor;
int analog_val;
String data;
String Hall;
String Temp;
WiFiClient client;
IPAddress server(192,168,43,169);
//char server[] = "google.com";
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// you're connected now, so print out the status:
printWifiStatus();
Hall = "50";
Temp = "50";
data = "";
void loop(){
currentMillis = millis();
if(currentMillis - previousMillis > interval) { // READ ONLY ONCE PER INTERVAL
Hall = String(50);
Temp = String(50);
data = "temp1="+Hall+"&hum1="+Temp;
client.flush();
if (client.connect(server,80)) { // REPLACE WITH YOUR SERVER ADDRESS
Serial.println("Connected");
client.println("POST /add.php HTTP/1.1");
client.println("Host: 192.168.43.169"); // SERVER ADDRESS HERE TOO
client.println("Content-Type: application/x-www-form-urlencode;charset=UTF-8");
client.println("User-Agent: Arduino/1.0");
client.print("Content-Length: ");
client.println(data.length());
client.println();
client.print(data+"\n");
Serial.println("POST /add.php HTTP/1.1");
Serial.println("Host: 192.168.43.169");
Serial.println("Content-Type: application/<span class=hiddenSpellError>x-www-form-urlencoded</span>");
Serial.println("Connection: close");
Serial.print("Content-Length: ");
Serial.println(data.length());
Serial.print(data);
if (client.connected()) {
char c = client.read();
Serial.write(c);
client.stop(); // DISCONNECT FROM THE SERVER
client.flush();
delay(70000); // WAIT FIVE MINUTES BEFORE SENDING AGAIN
Serial.println("Noo");
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
mokete:
To receive useful responces:
Put some error message into your code
Capture those error message
attach the Captured Error message to your help request
Just saying it cannot post leaves too many possibilities.
Unless someone has used your exact software, and encountered the exact same problem, no one will be able to help you.
Chuck.
Check out my Kickstarter Project Memory Panes an expansion RAM Shield for Mega2560's. It adds 1MB of RAM for those projects where 8KB is not enough.
The php code to which the data is sent to has no errors, and if data is inserted manually it is okay e.g($query = "INSERT INTO tempLog (timeStamp, temperature, humidity)
VALUES (NOW(),11, 11)";).I am using arduino uno 1.06 with a wifi shield.For server I am using WAMP.The database is okay but when i try to send thee data via arduino the entrys in database table are zeroes.BELOW IS THE PHP CODE:
mokete:
void loop(){
Hall = String(50);
Temp = String(50);
client.flush();
client.println();
Serial.write(c);
client.flush();
Ok, looking at your code, it has some issues.
You are reading your sensors once per interval, but you are delaying 5 minutes between transactions.
your program flow should be:
Initialize Wifi, connect to network
loop top:
if(interval elapsed)
if(Connect to Server)
Read Sensor
Post to Server
Wait for Post acknowledgement
Disconnect from Server
error(connection failed)
Set next interval
goto top:
your Current program is
loop top:
Read Sensor
if(Connect to Server) //whether or not new Data?
Post to server
if(Connected)
don't wait for characters, just read one character
close connection
flush connection
delay(5minutes)
goto top:
unsigned long timeout=millis();
void loop(){
if(millis()>timeout){
if(WIFI.status()==WL_CONNECTED){
client.flush();
read Sensors
client.print( all of post data );
while(client.connected()){ // connection is still open, may have status data waiting
if(client.available()) Serial.print(client.read());
client.close();
timeout = millis()+interval;
else {
error("unable to connect to server");
timeout = millis() + interval/4
else {
error("WiFi not connected");
WIFI.begin();
timeout = millis() + 10000; // see if Wifi will reconnect
Chuck.
