Cannot prevent block after calling method
Hello everyone, lately I've been working on an application for reaction to envirometal music. For this I used as a basis the code provided by Stephan Schultz (GitHub - Steppschuh/Micro-Beat-Detection: Beat detection using microphone input on microcontrollers).
I have implemented some alternatives to this funcionality wich can be called in the loop depending on the selected mode.
My problem comes when I use the method that implements Stephan Schultz code, since once it runs, if I try to switch to my other music detection mode it blocks.
I belive the problem might be related to this specific part of the code, but its a happy guess:
void setupADC() {
  ADCSRA = 0xe0+7; // "ADC Enable", "ADC Start Conversion", "ADC Auto Trigger Enable" and divider.
  ADMUX = 0x0; // use adc0. Use ARef pin for analog reference (same as analogReference(EXTERNAL)).
  ADMUX |= 0x40; // Use Vcc for analog reference.
  DIDR0 = 0x01; // turn off the digital input for adc0
I will aslo attatch all the code in case it helps:
#define LOG_OUT 1 // use the log output function
#define FHT_N 128 // amount of bins to use
#include <SoftwareSerial.h>
#include <FHT.h> // include the library
#define FreqLog // use log scale for FHT frequencies
#define FreqGainFactorBits 0
#define FreqSerialBinary
#define VolumeGainFactorBits 0
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
#ifdef __AVR__
#include <avr/power.h> // Required for 16 MHz Adafruit Trinket
#endif
#define PIN      6
#define NUMPIXELS 14
SoftwareSerial BTserial(2, 3); // RX | TX
Adafruit_NeoPixel pixels(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
//Configurable parameters
int mode = 0; //Mode of functioning
float sensitivity=0.23;
float restaIntensidad = 0.005;//Rate at wich the light fades
float rojo = 255;
float verde = 255;
float azul = 255;
bool firstTime = true; //Boolean used for executing specail part of Stephan Shultz setup code
int sensorValue1;
int sensorValue2;
int sensorValue3;
int nSamples = 150;
int values[150];
int valuesIndex=0;
float suma = 0;
int media = 0;
float threshhold;
int maxValue;
int minValue;
float rojoActual=0;
float verdeActual=0;
float azulActual =0;
//BT
// Set to true if you want to use the FHT 128 channel analyser to visualize
// the detected frequencies. Will disable beat detection.
const bool LOG_FREQUENCY_DATA = false;
// Set to true if the light should be based on detected beats instead
// of detected amplitudes.
const bool PERFORM_BEAT_DETECTION = false;
const int SOUND_REFERENCE_PIN = 8; // D8
const int HAT_LIGHTS_PIN = 9; // D9
const int HAT_LIGHTS_LOW_PIN = 11; // D11
const int HAT_LIGHTS_HIGH_PIN = 12; // D12
const int HAT_LIGHTS_PULSE_PIN = 13; // D13
const int LIGHT_PULSE_DELAY = 10000;
const int LIGHT_PULSE_DURATION = 2000;
const int LIGHT_FADE_OUT_DURATION = 200; // good value range is [100:1000]
const float MINIMUM_LIGHT_INTENSITY = 0; // in range [0:1]
const float MAXIMUM_LIGHT_INTENSITY = 1; // in range [0:1]
const int MAXIMUM_SIGNAL_VALUE = 1024;
const int OVERALL_FREQUENCY_RANGE_START = 2; // should be 0, but first 2 bands produce too much noise
const int OVERALL_FREQUENCY_RANGE_END = FHT_N / 2;
const int OVERALL_FREQUENCY_RANGE = OVERALL_FREQUENCY_RANGE_END - OVERALL_FREQUENCY_RANGE_START;
const int FIRST_FREQUENCY_RANGE_START = 2;
const int FIRST_FREQUENCY_RANGE_END = 4;
const int FIRST_FREQUENCY_RANGE = FIRST_FREQUENCY_RANGE_END - FIRST_FREQUENCY_RANGE_START;
const int SECOND_FREQUENCY_RANGE_START = 2;
const int SECOND_FREQUENCY_RANGE_END = 6;
const int SECOND_FREQUENCY_RANGE = SECOND_FREQUENCY_RANGE_END - SECOND_FREQUENCY_RANGE_START;
const int MAXIMUM_BEATS_PER_MINUTE = 200;
const int MINIMUM_DELAY_BETWEEN_BEATS = 60000L / MAXIMUM_BEATS_PER_MINUTE;
const int SINGLE_BEAT_DURATION = 100; // good value range is [50:150]
const int FREQUENCY_MAGNITUDE_SAMPLES = 5; // good value range is [5:15]
int frequencyMagnitudeSampleIndex = 0;
int currentOverallFrequencyMagnitude = 0;
int totalOverallFrequencyMagnitude = 0;
int averageOverallFrequencyMagnitude = 0;
int overallFrequencyMagnitudeVariance = 0;
byte overallFrequencyMagnitudes[FREQUENCY_MAGNITUDE_SAMPLES];
int currentFirstFrequencyMagnitude = 0;
int totalFirstFrequencyMagnitude = 0;
int averageFirstFrequencyMagnitude = 0;
int firstFrequencyMagnitudeVariance = 0;
byte firstFrequencyMagnitudes[FREQUENCY_MAGNITUDE_SAMPLES];
int currentSecondFrequencyMagnitude = 0;
int totalSecondFrequencyMagnitude = 0;
int averageSecondFrequencyMagnitude = 0;
int secondFrequencyMagnitudeVariance = 0;
byte secondFrequencyMagnitudes[FREQUENCY_MAGNITUDE_SAMPLES];
int currentSignal = 0;
int totalSignal = 0;
int averageSignal = 0;
int signalVariance = 0;
byte signals[FREQUENCY_MAGNITUDE_SAMPLES];
long lastBeatTimestamp = 0;
long durationSinceLastBeat = 0;
float beatProbability = 0;
float beatProbabilityThreshold = 0.5;
long lightIntensityBumpTimestamp = 0;
float lightIntensityBumpValue = 0;
float lightIntensityValue = 0;
long lastPulseTimestamp = 0;
  pixels.begin();
  for(int i = 0; i < nSamples; i++){
    values[i]=390;
  Serial.println("Arduino is ready");
  // HC-05 default serial speed for commincation mode is 9600
  BTserial.begin(9600);
  while (BTserial.available() > 0) {
         BTserial.read();
  //El modo cero estara activo hasta que se cambie, indicando que se necesita conectar la app BT
  readBT();
  switch(mode){
    case 0:
      btSearchMode();
    case 1:
      pulsatingMode();
    case 2:
      onMode();
    case 3:
      offMode();
    case 4:
      audioDetectionMode();
    case 5:
      beatDetectionMode();
    default:
      Serial.println("Unregistered mode");
//Funcion encargada de apagar todas las luces del dispositivo
void offMode(){
  pixels.setPixelColor(0, pixels.Color(0,0,0));
  pixels.show();
//Funcion encargada de encender todas las luces del dispositivo
void onMode(){
  pixels.setPixelColor(0, pixels.Color(rojo, verde, azul));
  pixels.show();
//Funcion encargada de crear un patron pulsante. Sera en modo neutro del dispositivo
void pulsatingMode(){
  if(restaIntensidad == 0){
  float restaRojo = restaIntensidad*rojo;
  float restaVerde = restaIntensidad*verde;
  float restaAzul = restaIntensidad*azul;
  rojoActual=rojo;
  azulActual=azul;
  verdeActual=verde;
  while(rojoActual>restaRojo||verdeActual>restaVerde||azulActual>restaAzul){
      if(rojoActual< restaRojo){
        rojoActual=0;
      else{
        rojoActual-=restaRojo;
      if(verdeActual<restaVerde){
        verdeActual=0;
      else{
        verdeActual-=restaVerde;
      if(azulActual<restaAzul){
        azulActual=0;
      else{
        azulActual-=restaAzul;
      pixels.setPixelColor(0, pixels.Color(rojoActual, verdeActual, azulActual));
      pixels.show();
      delay(20);
    while(rojoActual<(rojo-restaRojo)||verdeActual<(verde-restaVerde)||azulActual<(azul-restaAzul)){
      if(rojoActual<(rojo-restaRojo)){
        rojoActual+=restaRojo;
      if(verdeActual<(verde-restaVerde)){
        verdeActual+=restaVerde;
      if(azulActual<(azul-restaAzul)){
        azulActual+=restaAzul;
      pixels.show();
      delay(20);
//Funcion encargada de crear un patron intermitente en las luces del dispositivo indicando la necesidad de conectar BT
void btSearchMode(){
  pixels.setPixelColor(0, pixels.Color(40, 40, 255));
  pixels.show();
  delay(150);
  pixels.show();
  delay(100);
  pixels.show();
  delay(400);
  pixels.show();
//Funcion encargada de leer los comandos Bluetooth y cambiar los parametros segun:
void readBT(){
  String lectura;
  char opcion = 'o';
  String nVel;
  String nmode;
  String nSens;
  String nrojo;
  String nverde;
  String nazul;
  // Keep reading from HC-05 and send to Arduino Serial Monitor
    if(BTserial.available()>0){
      lectura = BTserial.readString();
      lectura.trim();
      Serial.println(lectura);
      opcion=lectura.charAt(0);
      Serial.print("La opcion elegida es ");
      Serial.println( opcion);
      switch(opcion){
        case 'v':
          nVel = lectura.substring(1,7);
          restaIntensidad= nVel.toFloat();
          Serial.print("Nueva velocidad: ");
          Serial.println(restaIntensidad);
        case 'm':
          nmode=lectura.substring(1,2);
          Serial.println("Nuevo modo: "+nmode);
          mode = nmode.toInt();
        case 's':
          nSens = lectura.substring(1,6);
          sensitivity= nSens.toFloat();
          Serial.print("Nueva sensitividad: ");
          Serial.println(sensitivity);
        case 'c':
          nrojo = lectura.substring(1,4);
          nverde = lectura.substring(4,7);
          nazul = lectura.substring(7,10);
          rojo = nrojo.toInt();
          verde = nverde.toInt();
          azul = nazul.toInt();
          Serial.println("Nuevo color: "+nrojo+" "+nverde+" "+nazul);
        default:
          Serial.print("Entering case ");
          Serial.println("default");
          Serial.println("Opcion desconocida: "+opcion);
      //Limpìamos la variable y el buffer
      lectura = "";
         BTserial.read();
//This mode takes the imput from three MAX9814 sensors, calculates a threshold based on the collection of signals and turns the leds on if the signal is above the threshold
void audioDetectionMode(){
  sensorValue1 = analogRead(A0);
  sensorValue2 = analogRead(A1);
  sensorValue3 = analogRead(A2);
  values[valuesIndex]=(sensorValue1+sensorValue2+sensorValue3)/3;
      suma+=values[i];
      //Estos ifs se encargan de encontrar el maximo y el minimo para poder calcular el limite de activación
      if(values[i]>maxValue){
        maxValue=values[i];
      if(values[i]<minValue){
        minValue=values[i];
    media = suma/nSamples;
    //Esta linea calcula el limite de activación
    threshhold = (maxValue-minValue)*sensitivity;
    if(values[valuesIndex]>media+threshhold||values[valuesIndex]<media-threshhold){
      rojoActual= rojo;
      verdeActual= verde;
      azulActual=azul;
    else{
        rojoActual=0;
      else{
        verdeActual=0;
      else{
        azulActual=0;
      else{
    pixels.show();
    valuesIndex=(valuesIndex+1)%(nSamples);
    maxValue = 0;
    minValue = 1000;
    suma=0;
 * From this point onward, this methods are created by Stephan Schultz (GitHub - Steppschuh/Micro-Beat-Detection: Beat detection using microphone input on microcontrollers)
 * Analog to Digital Conversion needs to be configured to free running mode
 * in order to read the sound sensor values at a high frequency.
 * See: http://maxembedded.com/2011/06/the-adc-of-the-avr/
void setupADC() {
void beatDetectionMode(){
  if(firstTime){
      setupADC();
      pinMode(LED_BUILTIN, OUTPUT);
      pinMode(HAT_LIGHTS_PIN, OUTPUT);
      pinMode(HAT_LIGHTS_LOW_PIN, OUTPUT);
      pinMode(HAT_LIGHTS_HIGH_PIN, OUTPUT);
      pinMode(HAT_LIGHTS_PULSE_PIN, OUTPUT);
      pinMode(SOUND_REFERENCE_PIN, OUTPUT);
      digitalWrite(HAT_LIGHTS_PIN, HIGH);
      digitalWrite(SOUND_REFERENCE_PIN, HIGH);
      analogWrite(HAT_LIGHTS_LOW_PIN, 255 * MINIMUM_LIGHT_INTENSITY);
      analogWrite(HAT_LIGHTS_HIGH_PIN, 255 * MAXIMUM_LIGHT_INTENSITY);
      for (int i = 0; i < FREQUENCY_MAGNITUDE_SAMPLES; i++) {
        overallFrequencyMagnitudes[i] = 0;
        firstFrequencyMagnitudes[i] = 0;
        secondFrequencyMagnitudes[i] = 0;
        signals[i] = 0;
      firstTime=false;
    if (LOG_FREQUENCY_DATA) {
      readAudioSamples();
      getFrequencyData();
      logFrequencyData();
      Serial.print(String(millis()));
      readAudioSamples();
      if (PERFORM_BEAT_DETECTION) {
        getFrequencyData();
        processFrequencyData();
        updateBeatProbability();
        updateLightIntensityBasedOnBeats();
        updateLightIntensityBasedOnAmplitudes();
      updateLights();
      Serial.println("");
 * Will read the sound sensor values from pin A0.
void readAudioSamples() {
  long currentAverage = 0;
  long currentMaximum = 0;
  long currentMinimum = MAXIMUM_SIGNAL_VALUE;
  for (int i = 0; i < FHT_N; i++) { // save 256 samples
    while (!(ADCSRA & /*0x10*/_BV(ADIF))); // wait for adc to be ready (ADIF)
    sbi(ADCSRA, ADIF); // restart adc
    byte m = ADCL; // fetch adc data
    byte j = ADCH;
    int k = ((int) j << 8) | m; // form into an int
    currentMinimum = min(currentMinimum, k);
    currentMaximum = max(currentMaximum, k);
    currentAverage += k;
    k -= 0x0200; // form into a signed int
    k <<= 6; // form into a 16b signed int
    k <<= FreqGainFactorBits;
    fht_input[i] = k; // put real data into bins
  currentAverage /= FHT_N;
  int signalDelta = currentMaximum - currentAverage;
  currentSignal = currentAverage + (2 * signalDelta);
  constrain(currentSignal, 0, currentMaximum);
  processHistoryValues(
    signals,
    frequencyMagnitudeSampleIndex,
    currentSignal,
    totalSignal,
    averageSignal,
    signalVariance
  //logValue("A", (float) currentAverage / MAXIMUM_SIGNAL_VALUE, 10);
  //logValue("M", (float) currentMaximum / MAXIMUM_SIGNAL_VALUE, 10);
  logValue("S", (float) currentSignal / MAXIMUM_SIGNAL_VALUE, 20);
 * Will run the Fast Hartley Transform to convert the time domain signals
 * to the frequency domain.
 * See: http://wiki.openmusiclabs.com/wiki/ArduinoFHT
void getFrequencyData() {
  fht_window(); // window the data for better frequency response
  fht_reorder(); // reorder the data before doing the FHT
  fht_run(); // process the data in the FHT
  fht_mag_log(); // get the magnitude of each bin in the FHT
void logFrequencyData() {
#ifdef FreqSerialBinary
  // print as binary
  Serial.write(255); // send a start byte
  Serial.write(fht_log_out, FHT_N / 2); // send out the data
#else
  // print as text
  for (int i = 0; i < FHT_N / 2; i++) {
      Serial.print(fht_log_out[i]);
      Serial.print(',');
#endif
 * Will extract insightful features from the frequency data in order
 * to perform the beat detection.
void processFrequencyData() {
  // each of the methods below will:
  //  - get the current frequency magnitude
  //  - add the current magnitude to the history
  //  - update relevant features
  processOverallFrequencyMagnitude();
  processFirstFrequencyMagnitude();
  processSecondFrequencyMagnitude();
  // prepare the magnitude sample index for the next update
  frequencyMagnitudeSampleIndex += 1;
  if (frequencyMagnitudeSampleIndex >= FREQUENCY_MAGNITUDE_SAMPLES) {
    frequencyMagnitudeSampleIndex = 0; // wrap the index
void processOverallFrequencyMagnitude() {
  currentOverallFrequencyMagnitude = getFrequencyMagnitude(
    fht_log_out,
    OVERALL_FREQUENCY_RANGE_START,
    overallFrequencyMagnitudes,
    currentOverallFrequencyMagnitude,
    totalOverallFrequencyMagnitude,
    averageOverallFrequencyMagnitude,
void processFirstFrequencyMagnitude() {
  currentFirstFrequencyMagnitude = getFrequencyMagnitude(
    fht_log_out,
    FIRST_FREQUENCY_RANGE_START,
    firstFrequencyMagnitudes,
    currentFirstFrequencyMagnitude,
    totalFirstFrequencyMagnitude,
    averageFirstFrequencyMagnitude,
void processSecondFrequencyMagnitude() {
  currentSecondFrequencyMagnitude = getFrequencyMagnitude(
    fht_log_out,
    SECOND_FREQUENCY_RANGE_START,
    secondFrequencyMagnitudes,
    currentSecondFrequencyMagnitude,
    totalSecondFrequencyMagnitude,
    averageSecondFrequencyMagnitude,
byte getFrequencyMagnitude(byte frequencies[], const int startIndex, const int endIndex) {
  int total = 0;
  int average = 0;
  int maximum = 0;
  int minimum = MAXIMUM_SIGNAL_VALUE;
  int current;
  for (int i = startIndex; i < endIndex; i++) {
    current = frequencies[i];
    total += current;
    maximum = max(maximum, current);
    minimum = min(minimum, current);
  average = total / (endIndex - startIndex);
  int value = average;
  //int value = maximum - average;
  //logValue("F", (float) value / 128, 10);
  return value;
void processHistoryValues(byte history[], int &historyIndex, int &current, int &total, int &average, int &variance) {
  total -= history[historyIndex]; // subtract the oldest history value from the total
  total += (byte) current; // add the current value to the total
  history[historyIndex] = current; // add the current value to the history
  average = total / FREQUENCY_MAGNITUDE_SAMPLES;
  // update the variance of frequency magnitudes
  long squaredDifferenceSum = 0;
    squaredDifferenceSum += pow(history[i] - average, 2);
  variance = (double) squaredDifferenceSum / FREQUENCY_MAGNITUDE_SAMPLES;
 * Will update the beat probability, a value between 0 and 1
 * indicating how likely it is that there's a beat right now.
void updateBeatProbability() {
  beatProbability = 1;
  beatProbability *= calculateSignalChangeFactor();
  beatProbability *= calculateMagnitudeChangeFactor();
  beatProbability *= calculateVarianceFactor();
  beatProbability *= calculateRecencyFactor();
  if (beatProbability >= beatProbabilityThreshold) {
    lastBeatTimestamp = millis();
  logValue("B", beatProbability, 5);
 * Will calculate a value in range [0:2] based on the magnitude changes of
 * different frequency bands.
 * Low values are indicating a low beat probability.
float calculateSignalChangeFactor() {
  float aboveAverageSignalFactor;
  if (averageSignal < 75 || currentSignal < 150) {
    aboveAverageSignalFactor = 0;
    aboveAverageSignalFactor = ((float) currentSignal / averageSignal);
    aboveAverageSignalFactor = constrain(aboveAverageSignalFactor, 0, 2);
  //logValue("SC", (float) currentSignal / 512, 10);
  //logValue("SA", (float) averageSignal / 512, 10);
  logValue("SF", aboveAverageSignalFactor / 2, 2);
  return aboveAverageSignalFactor;
 * Will calculate a value in range [0:1] based on the magnitude changes of
float calculateMagnitudeChangeFactor() {
  float changeThresholdFactor = 1.1;
  if (durationSinceLastBeat < 750) {
    // attempt to not miss consecutive beats
    changeThresholdFactor *= 0.95;
  } else if (durationSinceLastBeat > 1000) {
    // reduce false-positives
    changeThresholdFactor *= 1.05;
  // current overall magnitude is higher than the average, probably
  // because the signal is mainly noise
  float aboveAverageOverallMagnitudeFactor = ((float) currentOverallFrequencyMagnitude / averageOverallFrequencyMagnitude);
  aboveAverageOverallMagnitudeFactor -= 1.05;
  aboveAverageOverallMagnitudeFactor *= 10;
  aboveAverageOverallMagnitudeFactor = constrain(aboveAverageOverallMagnitudeFactor, 0, 1);
  // current magnitude is higher than the average, probably
  // because the there's a beat right now
  float aboveAverageFirstMagnitudeFactor = ((float) currentFirstFrequencyMagnitude / averageFirstFrequencyMagnitude);
  aboveAverageOverallMagnitudeFactor -= 0.1;
  aboveAverageFirstMagnitudeFactor *= 1.5;
  aboveAverageFirstMagnitudeFactor = pow(aboveAverageFirstMagnitudeFactor, 3);
  aboveAverageFirstMagnitudeFactor /= 3;
  aboveAverageFirstMagnitudeFactor -= 1.25;
  aboveAverageFirstMagnitudeFactor = constrain(aboveAverageFirstMagnitudeFactor, 0, 1);
  float aboveAverageSecondMagnitudeFactor = ((float) currentSecondFrequencyMagnitude / averageSecondFrequencyMagnitude);
  aboveAverageSecondMagnitudeFactor -= 1.01;
  aboveAverageSecondMagnitudeFactor *= 10;
  aboveAverageSecondMagnitudeFactor = constrain(aboveAverageSecondMagnitudeFactor, 0, 1);
  float magnitudeChangeFactor = aboveAverageFirstMagnitudeFactor;
  if (magnitudeChangeFactor > 0.15) {
    magnitudeChangeFactor = max(aboveAverageFirstMagnitudeFactor, aboveAverageSecondMagnitudeFactor);
  if (magnitudeChangeFactor < 0.5 && aboveAverageOverallMagnitudeFactor > 0.5) {
    // there's no bass related beat, but the overall magnitude changed significantly
    magnitudeChangeFactor = max(magnitudeChangeFactor, aboveAverageOverallMagnitudeFactor);
    // this is here to avoid treating signal noise as beats
    //magnitudeChangeFactor *= 1 - aboveAverageOverallMagnitudeFactor;
  //float maximumMagnitude = 128; //128;
  //logValue("CO", (currentOverallFrequencyMagnitude - averageOverallFrequencyMagnitude) / maximumMagnitude, 5);
  //logValue("C1", (currentFirstFrequencyMagnitude - averageFirstFrequencyMagnitude) / maximumMagnitude, 5);
  //logValue("C2", (currentSecondFrequencyMagnitude - averageSecondFrequencyMagnitude) / maximumMagnitude, 5);
  //logValue("CO", (currentOverallFrequencyMagnitude) / maximumMagnitude, 10);
  //logValue("C1", (currentFirstFrequencyMagnitude) / maximumMagnitude, 10);
  //logValue("C2", (currentSecondFrequencyMagnitude) / maximumMagnitude, 10);
  logValue("AO", aboveAverageOverallMagnitudeFactor, 2);
  logValue("A1", aboveAverageFirstMagnitudeFactor, 10);
  logValue("A2", aboveAverageSecondMagnitudeFactor, 10);
  //logValue("A1|2", max(aboveAverageFirstMagnitudeFactor, aboveAverageSecondMagnitudeFactor), 1);
  logValue("M", magnitudeChangeFactor, 1);
  return magnitudeChangeFactor;
 * Will calculate a value in range [0:1] based on variance in the first and second
 * frequency band over time. The variance will be high if the magnitude of bass
 * frequencies changed in the last few milliseconds.
float calculateVarianceFactor() {
  // a beat also requires a high variance in recent frequency magnitudes
  float firstVarianceFactor = ((float) (firstFrequencyMagnitudeVariance - 50) / 20) - 1;
  firstVarianceFactor = constrain(firstVarianceFactor, 0, 1);
  float secondVarianceFactor = ((float) (secondFrequencyMagnitudeVariance - 50) / 20) - 1;
  secondVarianceFactor = constrain(secondVarianceFactor, 0, 1);
  float varianceFactor = max(firstVarianceFactor, secondVarianceFactor);
  logValue("V", varianceFactor, 1);
  return varianceFactor;
 * Will calculate a value in range [0:1] based on the recency of the last detected beat.
float calculateRecencyFactor() {
  float recencyFactor = 1;
  durationSinceLastBeat = millis() - lastBeatTimestamp;
  int referenceDuration = MINIMUM_DELAY_BETWEEN_BEATS - SINGLE_BEAT_DURATION;
  recencyFactor = 1 - ((float) referenceDuration / durationSinceLastBeat);
  recencyFactor = constrain(recencyFactor, 0, 1);
  //logValue("R", recencyFactor, 5);
  return recencyFactor;
 * Will update the light intensity bump based on the recency of detected beats.
void updateLightIntensityBasedOnBeats() {
  float intensity = 1 - ((float) durationSinceLastBeat / LIGHT_FADE_OUT_DURATION);
  intensity = constrain(intensity, 0, 1);
  if (intensity > lightIntensityValue) {
    lightIntensityBumpValue = intensity;
    lightIntensityBumpTimestamp = millis();
 * Will update the light intensity bump based on measured amplitudes.
void updateLightIntensityBasedOnAmplitudes() {
  float intensity;
  if (averageSignal < 1 || currentSignal < 1) {
    intensity = 0;
    intensity = (float) (currentSignal - averageSignal) / MAXIMUM_SIGNAL_VALUE;
    intensity *= pow(intensity, 3);
    if (intensity < 0.1) {
      intensity = 0;
      intensity -= 0.1;
      intensity = pow(1 + intensity, 3) - 1;
  logValue("I", intensity, 10);
 * Will update the hat lights based on the last light intensity bumps.
void updateLights() {
  long durationSinceLastBump = millis() - lightIntensityBumpTimestamp;
  float fadeFactor = 1 - ((float) durationSinceLastBump / LIGHT_FADE_OUT_DURATION);
  fadeFactor = constrain(fadeFactor, 0, 1);
  lightIntensityValue = lightIntensityBumpValue * fadeFactor;
  lightIntensityValue = constrain(lightIntensityValue, 0, 1);
  logValue("L", lightIntensityValue, 20);
  // scale the intensity to be in range of maximum and minimum
  float scaledLightIntensity = MINIMUM_LIGHT_INTENSITY + (lightIntensityValue * (MAXIMUM_LIGHT_INTENSITY - MINIMUM_LIGHT_INTENSITY));
  int pinValue = 255 * scaledLightIntensity;
  int rojoActual = rojo * scaledLightIntensity;
  int verdeActual = verde * scaledLightIntensity;
  int azulActual = azul * scaledLightIntensity;
  pixels.show();
  analogWrite(HAT_LIGHTS_PIN, pinValue);
  // also use the builtin LED, for debugging when no lights are connected
  if (scaledLightIntensity > MAXIMUM_LIGHT_INTENSITY - ((MAXIMUM_LIGHT_INTENSITY - MINIMUM_LIGHT_INTENSITY) / 4)) {
    digitalWrite(LED_BUILTIN, HIGH);
    digitalWrite(LED_BUILTIN, LOW);
  // update the pulse signal
  long durationSincePulse = millis() - lastPulseTimestamp;
  fadeFactor = ((float) durationSincePulse / (LIGHT_PULSE_DURATION * 2));
  if (durationSincePulse >= LIGHT_PULSE_DURATION) {
    fadeFactor = 1 - fadeFactor;
  fadeFactor *= 2;
  scaledLightIntensity = MINIMUM_LIGHT_INTENSITY + (fadeFactor * (MAXIMUM_LIGHT_INTENSITY - MINIMUM_LIGHT_INTENSITY));
  //logValue("P", scaledLightIntensity, 10);
  analogWrite(HAT_LIGHTS_PULSE_PIN, pinValue);
  if (durationSincePulse >= LIGHT_PULSE_DELAY) {
    lastPulseTimestamp = millis();
 * Converts the specified value into an ASCII-art progressbar
 * with the specified length.
String toProgressBar(float value, const int length) {
  int amount = max(0, min(length, value * length));
  String progressBar = "[";
  for (int i = 0; i < amount; i++) {
    progressBar += "=";
  for (int i = 0; i < length - amount; i++) {
    progressBar += " ";
  progressBar += "]";
  return progressBar;
void logValue(String name, boolean value) {
  logValue(name, value ? 1.0 : 0.0, 1);
void logValue(String name, float value) {
  logValue(name, value, 10);
void logValue(String name, float value, int length) {
  Serial.print(" | " + name + ": " + toProgressBar(value, length));
I dont fully understand the imlemented code, if someone can point me in the right direction I would be greatfull.
Also any suggestions about the code are appreciated! Im farly new to Arduino so any improovement is a win.
Hi
I am forget, what is your board?
Hello again! Its a Arduino NANO with a ATMEGA328P Processor
Looks like memory fragmentation.
You have a lot functions, arrays, structures and strings in your code. I seems to much for old small Nano :slight_smile:
At least try to move all constant strings to the flash memory - you win a couple hundreds bytes...
It tells me that only 50% of the memory is occupied and 60% of dinamic memory, but honestly I dont know how to interpret that.
Anyway, by moving all constant strings to flash memory you mean put them inside in the methods right?
No. It means to put the constants in the controller's on-board flash memory - using the keyword PROGMEM, found here: https://www.arduino.cc/reference/en/
no, I meant using the F() macro
PROGMEM and F() macro
So if I understood correctly the page you sent mefor the the F() macro, it works for not filling the ram while doing plenty of Serial Prints. Since its true that the implemented code had plenty of prints I took them out first to see if it mght be the problem. Unfortunatedly this has not solved the block, please tell me if im understanding the F() macro incorrectly.
I don't think that you misunderstood.
Please post your revised code so we can see what your code looks like now.
