Hiya folks,
Your help would be much appreciated on this problem…
I’ve built a sketch that attempts to do a couple of different lengths of windowing and some simple calculations (mean/variance) on the analog values from a couple of sensors. Previously I had the same code for 1 sensor working as intended but the code below has been expanded with a bunch of little for loops so that everything should run for both sensors now.
I simply can’t get anything at all to print to serial - even the two serial prints i put in setup and start of loop just to debug - yet the code compiles and uploads without any errors or warnings.
I apologise for including the whole sketch, I couldn’t think how to break it apart to show.
long int currentTime = 0;
long int stopTime[2] = {0,0};
long int shortWindowTime = 0;
int shortVal[2][40];
int reflexWindowStart = 0;
int reflexWindowTime = 0;
int reflexVal[2][500];
int mean[2] = {0,0};
unsigned int variance[2] = {0,0};
int lowVal[2] = {0,0};
int peakVal[2] = {0,0};
int lowIndex[2] = {0,0};
int peakIndex[2] = {0,0};
int stopIndex[2] = {0,0};
boolean stopped[2] = {false,false};
void setup(){
Serial.println("wtf?");
for(int i=0;i<2;i++){
for(int j=0;j<40;j++){
shortVal[i][j] = 0;
for(int j=0;j<500;j++){
reflexVal[i][j] = 1023;
currentTime = micros();
if(currentTime - shortWindowTime > 500){
shortWindowTime = currentTime;
writeShortWindow();
meanVariance();
if(reflexWindowStart == 0){
reflexWindow();
reflexWindowStart++;
if(reflexWindowStart > 9){
void writeShortWindow(){
for(int j=39; j>0; j--){
shortVal[i][j] = shortVal[i][j-1];
int ground = analogRead(A5);
shortVal[0][0] = analogRead(A1);
analogRead(A5);
shortVal[i][0] = analogRead(A2);
void meanVariance(){
for(int j=0; j<39; j++){
mean[i] = mean[i] + shortVal[i][j];
mean[i] = mean[i] / 40;
variance[i] = variance[i] + sq(mean[i] - shortVal[i][j]) ;
variance[i] = variance[i] / 40;
void reflexWindow(){
if(stopped[i] == true){
if((millis() - stopTime[i] > 20) && (peakVal[i] - shortVal[i][0] > 20) && (variance[i] <= 1)){
stopped[i] = false;
stopIndex[i] = 0;
Serial.println("................................NOTstopped");
if(stopped[i] == false){
lowVal[i] = 1023;
peakVal[i] = 0;
for(int j=stopIndex[i]; j>0; j--){
reflexVal[i][j] = reflexVal[i][j-1];
if(reflexVal[i][j] < lowVal[i]){
lowVal[i] = reflexVal[i][j];
lowIndex[i] = j;
reflexVal[i][0] = shortVal[i][0];
for(int j=lowIndex[i]; j>=0; j--){
if(reflexVal[i][j] > peakVal[i]){
peakVal[i] = reflexVal[i][j];
if(peakVal[i] - lowVal[i] >= 50){
Serial.print(i);
Serial.println("...................................stopped");
stopTime[i] = millis();
stopped[i] = true;
if(stopIndex[i] < 499){
stopIndex[i]++;
Serial.print(shortVal[0][0]);
Serial.print(" ... ");
Serial.print(lowVal[0]);
Serial.print(peakVal[0]);
Serial.print(" ........ ");
Serial.print(shortVal[1][0]);
Serial.print(lowVal[1]);
Serial.println(peakVal[1]);
Cheers!
MrJack
