Hi I have a problem, when I used Yosemite I could communicate to my Arduino ProMini 3.3V 8MHz configuration using Arduino IDE 1.6.5 with "Foca USB to Serial Converter (Foca USB to Serial Converter - CRCibernética)".
But now that I upgrade my computer to OS X El Capitan, there is an error in my IDE 1.6.5 that says:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
It doesn't have the normal 6-pin header, and the pins are in a weird order, so you'll need to use some care in wiring it up. If you think it's wired right, try swapping TX and RX (this is an incredibly easy mistake to make - I always try swapping those, even when I'm sure I got it right; It's susprising how often I didn't)
I finally could! I install again the VCP Drivers - FTDI for my MAC and then Restarted it. Then I switch the TX and RX and It worked out!
Thank you so much DrAzzy!
The finally pin configuration is:
TX in FOCA --> RX in ArduinoProMini
RX in FOCA --> TX in ArduinoProMini
VCCIO in FOCA --> VCC in ArduinoProMini
GND in FOCA --> GND in ArduinoProMini
DTR in FOCA --> GRN in ArduinoProMini
So the first question to be asked was - "Apart from upgrading the OS, did you do anything else - such as perhaps, pulling the board down and reconnecting it?"
After reboot, i installed the Driver 2.2.18 (2012). But in the Dokument above is a new driver 2.3.0 (2015). I can not this new 2.3.0 version of the FTDI-Driver
The 2.2.18 will not run
Arduino says:
stk500_recv(): programmer is not responding
