Cannot read PORTC
Hi
Arduino Nano.
I want to read a binary switch on PORTC ,A0,A1,A2.Common pin to ground and 10k pullup resistors on A0,A1,A2.
Then output the value from the binary switch on PORTD.
If I run this all 3 leds on PORTD pulse on and off,but the binary switch does not change the leds.
 /*  TEST POTRD
    while(1)
    PORTD = 0X00;
    PORTD = 0XFF;
Below is my full not working best effort.
  DDRD = 0XFF;//PORTD all output
  pinMode (14, INPUT);
  pinMode (15, INPUT);
  pinMode (16, INPUT);
  DataSelect = digitalRead(PORTC);//read portc
  DataSelect & B00000111;//mask off 5 upper bits
  /*  TEST POTRD
    while(1)
    PORTD = 0X00;
    PORTD = 0XFF;
  if (DataSelect == 0)//1
    PORTD = 0;
  if (DataSelect == 1)//2
    PORTD = 1;
  if (DataSelect == 2)//3
    PORTD = 2;
  if (DataSelect == 3)//4
    PORTD = 3;
  if (DataSelect == 4)//5
    PORTD = 4;
  if (DataSelect == 5)//6
    PORTD = 5;
  if (DataSelect == 6)//7
    PORTD = 6;
  if (DataSelect == 7)//8
    PORTD = 7;
Please help..all the samples I could find only read single PINS.
Revised version of your codes -- validate the necessity.
  byte DataSelect = PINC;//digitalRead(PORTC);//read portc
  DataSelect = DataSelect & B00000111;//mask off 5 upper bits
  /*  TEST POTRD
    while(1)
    PORTD = 0X00;
    PORTD = 0XFF;
    PORTD = 0;
    PORTD = 1;
    PORTD = 2;
    PORTD = 3;
    PORTD = 4;
    PORTD = 5;
    PORTD = 6;
    PORTD = 7;
Reference Reading:
Thanks Golamostafa
You fix my problem..it is working!
I searched for 2 day for this.
Thanks.
