Cannot read serial data from Venus GPS
I just received a venus GPS module from sparkfun and I am trying to hook it up on an arduino pro 3.3v.
The gps seems to work fine using the FTDI chip and hyperterminal. I get steady transmits of NMEA on 9600
However, when I try to read the data using arduino, I never seem to be able to read things.
I have tried both hardware serial and software serial, but nothing seems to work.
Can anyone please post some code that is actually working so that I can test my setup?
I have vcc and gnd hooked on arduino VCC (3.13v) and gnd, and I have hooked venus TX to arduino 0(RX) and its RX to 1(TX).
Any suggestions?
post your code
I was using the basic and crude serial reader for debugging .
But nothing happens
By the way, I am powering both arduino and venus through FTDI.
Does it provide enough current to normally power both of them?
int incomingByte = 0;      // for incoming serial data
      Serial.begin(9600);      // opens serial port, sets data rate to 9600 bps
      // send data only when you receive data:
      if (Serial.available() > 0) {
            // read the incoming byte:
            incomingByte = Serial.read();
            // say what you got:
            Serial.print("I received: ");
            Serial.println(incomingByte, DEC);
you got to tell it where you're getting it from... look at my post about my gps it may help you
Are you sure you should be using a byte to store the GPS info? I think a string would be more appropriate.
I have a GPS with the same chipset used on Venus GPS, and I solved the problem for mine.
If anyone is willing to try:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278896700/0
Cheers,
Antonio Santos
