Hello,
Because I have only an ESP32 board and a DHT11 sensor, but not a ready-made code, I tried to join two existing code samples together, one for displaying DHT sensor values (ESP32 with DHT11/DHT22 Temperature and Humidity Sensor using Arduino IDE | Random Nerd Tutorials) and another one made for sending BME280 sensor values to Thingspeak (ESP32 Publish Sensor Readings to ThingSpeak (easiest way) | Random Nerd Tutorials). After joining the two somewhat together, this is what I have in the editor of Arduino IDE (v. 1.8.16):
#include "DHT.h"
#include <WiFi.h>
#include "ThingSpeak.h"
#define DHTPIN 14
#define DHTTYPE DHT11
const char* ssid = "123459"; // your network SSID (name)
const char* password = "48GSMKJREGGYE"; // your network password
WiFiClient client;
unsigned long myChannelNumber = 2;
const char * myWriteAPIKey = "NW3MMODKJS1NGRL2";
// Timer variables
unsigned long lastTime = 0;
unsigned long timerDelay = 10000;
DHT dht(DHTPIN, DHTTYPE);
Serial.println(F("DHT11 test!"));
dht.begin();
WiFi.mode(WIFI_STA);
ThingSpeak.begin(client);
delay(20000);
float h = dht.readHumidity();
float t = dht.readTemperature();
float f = dht.readTemperature(true);
if (isnan(h) || isnan(t) || isnan(f)) {
Serial.println(F("Failed to read from DHT sensor!"));
return;
if(WiFi.status() != WL_CONNECTED){
Serial.print("Attempting to connect");
while(WiFi.status() != WL_CONNECTED){
WiFi.begin(ssid, password);
delay(5000);
Serial.println("\nConnected.");
float hif = dht.computeHeatIndex(f, h);
float hic = dht.computeHeatIndex(t, h, false);
Serial.print(F("Humidity: "));
Serial.print(h);
Serial.print(F("% Temperature: "));
Serial.print(t);
Serial.print(F("°C "));
Serial.print(f);
Serial.print(F("°F Heat index: "));
Serial.print(hic);
Serial.print(hif);
Serial.println(F("°F"));
int x = ThingSpeak.writeFields(myChannelNumber, myWriteAPIKey);
if(x == 200){
Serial.println("Channel update successful.");
else{
Serial.println("Problem updating channel. HTTP error code " + String(x));
And then, this is the output:
sketch_dht11esp32:83:1: error: expected unqualified-id before 'if'
if(x == 200){
sketch_dht11esp32:86:1: error: expected unqualified-id before 'else'
else{
Multiple libraries were found for "WiFi.h"
Used: /home/lauri/.arduino15/packages/esp32/hardware/esp32/2.0.0/libraries/WiFi
Not used: /home/lauri/Arduino/libraries/WiFi
exit status 1
I cannot come up with a solution for the if-error. I looked through a similar error post , but my if-statements don't seem to be outside of any bigger function. The notification about the Wifi library I guess is irrelevant for resolving the errors.
Thanks for any advice!
