Cannot see RF from 433Mhz transmitter
Hello,
I use an Uno + RXB12 433MHz receiver + RemoteReceiver library.
With a 'common' 'Klik Aan Klik Uit' RC I can see data coming in.
With a RC from a Fatboy Edison the Grande outdoor lamp the Arduino does not respond.
However, the latter RC has a JMR-TX-1 433MHz transmitter which works since the Fatboy lamp responds perfectly.
Any hints how to solve the issue: I want to have the Arduino send out the RC code to the lamp.
Thanks!
Kind regards,
John
The rf signal will be coded in some way - to reproduce it you'll have to find the codes.
An oscilloscope or logic analyser would help here.
The rip-off Chinese copies of the Saleae logic analysers are brilliant, and for a fiver you can't go wrong.
Allan
Blog on decoding RF signals.
