Hello,
I've reached the limit of fault finding and forum searching. Why wont my MKRFOX communicate with SigFox??
I've been through the first configuration (activated here) and the device appears in the Sigfox backend - although with no messages having been sent so there is no communications data.
I have looked at detail maps of coverage in my area (UK), correctly fitted the aerial that came from Arduino, also tried in a number of different areas around the UK.
In the sigfox backend I have changed the downlink mode to DIRECT.
I've had the MKRFOX for a few years now and couldn't get it working originally. But picked it up the other day any thought it was just a waste if I do not persist. I contacted SigFox and they have renewed my contract and I have one token allocated to the DevKit.
The MRKFOX seems to be functioning as expected, runs code nicely, but the first configuration code just returns with:
"No transmission
OK
PA OFF
Could not get any response from the server
Check the SigFox coverage in your area
If you are indoor, check the 20dB coverage or move near a window"
