Cannot send CAN message to DIJ C610
Arduino and MCP2515 are used to control M2006 using DJI C610.
The CAN of the C610 and the H/L of the MCP2515 are interconnected and both terminators are enabled. Then each pin of Arduino UNO R4 WiFi and MCP2515 is connected as follows.
INT : D2
SCK : D13
SI: D11
SO : D12
CS: D10
GND : GND
VCC: 5V
As a result, CAN0.begin() operates normally, but CAN0.sendMsgBuf() does not. How can I get CAN0.sendMsgBuf() to work correctly?
The source code and operation results are described below.
code------
#include <SPI.h>
#include <mcp_can.h>
#define SS_Robomas_C610 10
MCP_CAN CAN0(SS_Robomas_C610);
const int CAN_bps = CAN_1000KBPS;
const int MCP_OSC = MCP_16MHZ;
void mcp2515_init() {
  restart:
  if(CAN0.begin(MCP_ANY, CAN_bps, MCP_OSC) == CAN_OK) {
    Serial.println("Success : MCP2515 Initialization");
  else {
    Serial.println("Fail : MCP2515 Initialization");
    goto restart;
  delay(100);
  CAN0.setMode(MCP_NORMAL);
  mcp2515_init();
void tx_can_message() {
  uint32_t tx_message = 0x200;
  uint8_t tx_data[8] = {0x07, 0xD0, 0x00, 0x00, 0x0, 0x0, 0x0, 0x0};
  Serial.print("Sending CAN message: ID=");
  Serial.print(tx_message, HEX);
  Serial.print("  ");
  Serial.print("Sending CAN data=");
  byte sendStat = CAN0.sendMsgBuf(tx_message, 0, 8, tx_data);
  for (int i = 0; i < 8; i++) {
    Serial.print(tx_data[i], HEX);
    Serial.print(" ");
  Serial.print("sendStat= ");
  if(sendStat == CAN_GETTXBFTIMEOUT){
    Serial.println("CAN_GETTXBFTIMEOUT");
  else if(sendStat == CAN_OK){
    Serial.println("CAN_OK");
  else if(sendStat == CAN_SENDMSGTIMEOUT){
    Serial.println("CAN_SENDMSGTIMEOUT");
  delay(100);
void rx_can_message() {
  unsigned char len = 0;
  unsigned char data[8];
  unsigned long int rx_message;
  if (CAN_MSGAVAIL == CAN0.checkReceive()) {
    CAN0.readMsgBuf(&rx_message, &len, data);
    if (rx_message == 0x201) {
      Serial.print("Receiving CAN message: ID= ");
      Serial.print(rx_message, HEX);
      Serial.print("  ");
      Serial.print("Receiving CAN data= ");
      for (int i = 0; i < len; i++) {
        Serial.print(data[i], HEX);
        Serial.print(" ");
      delay(100);
  tx_can_message();
  rx_can_message();
  delay(100);
Serial Monitor-------
Entering Configuration Mode Successful!
Setting Baudrate Successful!
Sending CAN message: ID=200  Sending CAN data= 7 D0 0 0 0 0 0 0 sendStat=CAN_SENDMSGTIMEOUT
Sending CAN message: ID=200  Sending CAN data= 7 D0 0 0 0 0 0 0 sendStat=CAN_GETTXBFTIMEOUT
(From here on out, the same message keeps coming.)
Welcome to the forum!
I think you're new here because you posted 4h minutes ago and you joined 4h minutes ago!
read this first (if you didn't, chances are, you did):
https://forum.arduino.cc/guidelines
I'm going to be honest, I'm not the right person for the job. :slightly_frowning_face:
Welcome! I need your help on a problem, I have a user with a CAN problem I would like to help out but I cannot see the project. No idea of how things are connected. The code looks great except I cannot see it. I need to let the OP know that the code needs to be posted and a simple schematic as I do not work work with word schematic descriptions.
If you have not guessed as of yet it is you.
Without the information I can only guess which I do not like to do. Good Luck!
