I am working on a project where I pass string one by one to Arduino from my android app using Bluetooth. The following is my java code.I send string values to this function one by one.The problem here is I receive only one value in the Arduino serial monitor.The remaining values are not received.
public static void getDistance(float x){
String xMoved = Float.toString(x);
Log.d(TAG, "getDistance: called");
try {
mBTSocket.getOutputStream().write(xMoved.getBytes());
} catch (IOException e) {
e.printStackTrace();
Log.d(TAG, "getDistance: "+e);
finally {
Log.d(TAG, "getDistance:"+"try catch successful");
The following is the the code in my arduino:
QuickPayPortal
/* Example sketch to control a 28BYJ-48 stepper motor with ULN2003 driver board and Arduino UNO. More info: https://www.makerguides.com */
// Include the Arduino Stepper.h library:
#include <Stepper.h>
// Define number of steps per rotation:
const int stepsPerRevolution = 2048;
// Wiring:
// Pin 8 to IN1 on the ULN2003 driver
// Pin 9 to IN2 on the ULN2003 driver
// Pin 10 to IN3 on the ULN2003 driver
// Pin 11 to IN4 on the ULN2003 driver
// Create stepper object called 'myStepper', note the pin order:
int state;
String command;
Stepper myStepper = Stepper(stepsPerRevolution,2,4,3,5);
// Set the speed to 5 rpm:
myStepper.setSpeed(15);
// Begin Serial communication at a baud rate of 9600:
if(Serial.available()){
command = Serial.readStringUntil('\n');
state = command.toInt();
Serial.println(state);
myStepper.step(state);
The following is my logcat:
Please find my attachment image
I am confused what am I doing wrong?Anybody please help me out with this.
