I'm using Arduino Due and I set the analog read and write resolution to 12-bit for better resolution. Basically all I do is to vary PWM duty cycle by controlling analog DC input voltage from 0 to 3.3V. The simple code as it is now works fine as follows:
int pwmPin9 = 9;
int analogPin0 = 0;
int val = 0;
pinMode(pwmPin9, OUTPUT); // sets the pin as output
analogWriteResolution(12);
analogReadResolution(12);
My problem is I need to set the frequency of the PWM output to 25kHz or at least something nearest above 25kHz.
I have been searching forums hours and couldn't find any solution. Here I came across a way but it doesn't work above 20kHz.
I made the following change in variant.h:
* PWM
#define PWM_INTERFACE PWM
#define PWM_INTERFACE_ID ID_PWM
#define PWM_FREQUENCY 20000
#define PWM_MAX_DUTY_CYCLE 4095
#define PWM_MIN_DUTY_CYCLE 0
#define PWM_RESOLUTION 12
* TC
#define TC_INTERFACE TC0
#define TC_INTERFACE_ID ID_TC0
#define TC_FREQUENCY 20000
#define TC_MAX_DUTY_CYCLE 255
#define TC_MIN_DUTY_CYCLE 0
#define TC_RESOLUTION 8
But it only works for 20kHz. If I set to 25kHz or 30kHz I don't get any error but also don't get any output :((
