I am using an Arduino Nano clone to program and use a small I2C, SH1106 OLED. While trying to create a function to give me the length of a char*(as all the solutions I found were for strings, and it would complain if they were replaced by char*), I wanted to convert the integer I got back to char*(due to how the library I am using works) and as such, I used sprintf. Everything was working just fine until i added sprintf, now It looks like my board is bricked, as I cannot upload anything anymore to it.
Code I'm trying to upload:
#include <OneBitDisplay.h>
#ifdef USE_BACKBUFFER
static uint8_t ucBackBuffer[1024];
#else
static uint8_t *ucBackBuffer = NULL;
#endif
#define SDA_PIN 32
#define SCL_PIN 26
#define RESET_PIN -1
#define OLED_ADDR -1
#define FLIP180 0
#define INVERT 0
#define USE_HW_I2C 1
#define MY_OLED OLED_128x64
#define OLED_WIDTH 128
#define OLED_HEIGHT 64
OBDISP obd;
int rc;
rc = obdI2CInit(&obd, MY_OLED, OLED_ADDR, FLIP180, INVERT, USE_HW_I2C, SDA_PIN, SCL_PIN, RESET_PIN, 800000L); // use standard I2C bus at 400Khz
char* msg = "This is a test to see if i can manage to scroll text vertically on this oled screen right here. I will write some more words here so that the text will go off screen, as the small font is really smaller than I originally expected.";
scroll_func(msg);
void scroll_func(char* msg){
obdSetTextWrap(&obd, 1);
int start=3;
for(int i=0; i<1380; i+=126){
if(start>=0){i=0;}
obdFill(&obd, 0x0, 1);
obdWriteString(&obd, i,0,start,(char *)msg, FONT_SMALL, 0, 1);
if(start>=0){start--;}
Function which broke everything(which was part of the above code block before):
char* len(char* msg){
int c=0;
char* length;
while(msg[c] != '.'){
c++;
sprintf(length, "%d", c);
return length;
Error code received:
Arduino: 1.8.12 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_modified_sketch_983438\scroll_func.ino: In function 'void loop()':
C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_modified_sketch_983438\scroll_func.ino:28:15: warning: ISO C++ forbids converting a string constant to 'char*' [-Wwrite-strings]
Sketch uses 7894 bytes (25%) of program storage space. Maximum is 30720 bytes.
Global variables use 826 bytes (40%) of dynamic memory, leaving 1222 bytes for local variables. Maximum is 2048 bytes.
C:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM6 -b57600 -D -Uflash:w:C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_build_269143/scroll_func.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Dragos SPiridon\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM6
Using Programmer : arduino
Overriding Baud Rate : 57600
AVR Part : ATmega328P
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p)
avrdude: reading input file "C:\Users\DRAGOS~1\AppData\Local\Temp\arduino_build_269143/scroll_func.ino.hex"
avrdude: writing flash (7894 bytes):
Writing | avrdude: stk500_recv(): programmer is not responding
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
From what I can deduce, the board cannot be written to anymore.
And yes, I have tried all of the first options such as switching COM ports from USB3 to 2, it is running the old Bootloader.
