Cannot upload blink example on Arduino Nano Every
Hello,
I am totally newbie on using Arduino and I bought a Nano Every.
While I am following the very basic steps on uploading the blink example I am still getting the following errors. I have tried from IDE 2, IDE 1.18 and from online editor from windows machine and the error is always the same. I was thinking to check if my board is broken but I don't know how, since I get the green led while it is connected. I also change several usb cables (the one I am using now is for data transfer ) and tried usb 2.0 and usb3.0 ports.
Is anything that can I do, except trying with a new board?
/usr/local/bin/arduino-cli compile --fqbn arduino:megaavr:nona4809:mode=on --libraries /home/builder/opt/libraries/latest --build-cache-path /tmp --output-dir /tmp/870012430/build --build-path /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3 -v /tmp/870012430/Blink
Using board 'nona4809' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7
Using core 'arduino' from platform in folder: /home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7
Detecting libraries used...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/sketch/Blink.ino.cpp -o /dev/null
Generating function prototypes...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/sketch/Blink.ino.cpp -o /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/preproc/ctags_target_for_gcc_minus_e.cpp
/home/builder/.arduino15/packages/builtin/tools/ctags/5.8-arduino11/ctags -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/preproc/ctags_target_for_gcc_minus_e.cpp
Compiling sketch...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-g++ -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega4809 -DF_CPU=16000000L -DARDUINO=10607 -DARDUINO_AVR_NANO_EVERY -DARDUINO_ARCH_MEGAAVR -DAVR_NANO_4809_328MODE -DMILLIS_USE_TIMERB3 -DNO_EXTERNAL_I2C_PULLUP -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino/api/deprecated -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/cores/arduino -I/home/builder/.arduino15/packages/arduino/hardware/megaavr/1.8.7/variants/nona4809 /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/sketch/Blink.ino.cpp -o /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/sketch/Blink.ino.cpp.o
Compiling libraries...
Compiling core...
Using previously compiled file: /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/core/variant.c.o
Using precompiled core: /tmp/core/core_arduino_megaavr_nona4809_mode_on_ca5d9b6a8ef92affb130f5c73b0a8e06.a
Linking everything together...
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-gcc -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -Wl,--section-start=.text=0x0 -mmcu=atmega4809 -o /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.elf /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/sketch/Blink.ino.cpp.o /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/core/variant.c.o /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/../core/core_arduino_megaavr_nona4809_mode_on_ca5d9b6a8ef92affb130f5c73b0a8e06.a -L/tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3 -lm
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O binary -R .eeprom /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.elf /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.bin
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.elf /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.eep
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-objcopy -O ihex -R .eeprom /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.elf /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.hex
/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5/bin/avr-size -A /tmp/arduino-build-88E4CC3AD9014939E24D1606A8B1BBF3/Blink.ino.elf
Sketch uses 1118 bytes (2%) of program storage space. Maximum is 49152 bytes.
Global variables use 22 bytes (0%) of dynamic memory, leaving 6122 bytes for local variables. Maximum is 6144 bytes.
Upload started
Programming with: Serial
Restarting in bootloader mode
Flashing with command:C:/Users/fakou/.arduino-create/arduino/avrdude/6.3.0-arduino17/bin/avrdude.exe -CC:/Users/fakou/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega4809 -cjtag2updi -PCOM4 -b115200 -e -D -Uflash:w:C:/Users/fakou/AppData/Local/Temp/arduino-create-agent853000581/Blink.hex:i -Ufuse2:w:0x01:m -Ufuse5:w:0xC9:m -Ufuse8:w:0x00:m {upload.extra_files}
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:/Users/fakou/.arduino-create/arduino/avrdude/6.3.0-arduino17/etc/avrdude.conf"
Using Port : COM4
Using Programmer : jtag2updi
Overriding Baud Rate : 115200
JTAG ICE mkII sign-on message:
Communications protocol version: 1
M_MCU:
boot-loader FW version: 1
firmware version: 1.07
hardware version: 1
S_MCU:
firmware version: 6.07
hardware version: 1
Serial number: 00:00:00:00:00:00
Device ID: JTAGICE mkII
AVR Part : ATmega4809
Chip Erase delay : 0 us
PAGEL : P00
BS2 : P00
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 0
StabDelay : 0
CmdexeDelay : 0
SyncLoops : 0
ByteDelay : 0
PollIndex : 0
PollValue : 0x00
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
prodsig 0 0 0 0 no 61 61 0 0 0 0x00 0x00
fuses 0 0 0 0 no 9 0 0 0 0 0x00 0x00
fuse0 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse1 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse2 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse4 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse5 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse6 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse7 0 0 0 0 no 1 0 0 0 0 0x00 0x00
fuse8 0 0 0 0 no 1 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 0 0 0x00 0x00
data 0 0 0 0 no 0 0 0 0 0 0x00 0x00
usersig 0 0 0 0 no 64 64 0 0 0 0x00 0x00
flash 0 0 0 0 no 49152 128 0 0 0 0x00 0x00
eeprom 0 0 0 0 no 256 64 0 0 0 0x00 0x00
Programmer Type : JTAGMKII_PDI
Description : JTAGv2 to UPDI bridge
M_MCU hardware version: 1
M_MCU firmware version: 1.07
S_MCU hardware version: 1
S_MCU firmware version: 6.07
Vtarget : 5.0 V
avrdude: jtagmkII_initialize(): Cannot locate "flash" and "boot" memories in description
avrdude: jtagmkII_reset(): timeout/error communicating with programmer (status -1)
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: jtagmkII_close(): timeout/error communicating with programmer (status -1)
avrdude done. Thank you.
Try the steps below:
Do a complete uninstall of your IDE ( https://support.arduino.cc/hc/en-us/articles/360021325733-How-to-do-a-complete-uninstall-of-the-Arduino-IDE ) and install the latest following https://support.arduino.cc/hc/en-us/articles/360019833020-How-to-install-the-Arduino-IDE
Install the package core for your board https://www.arduino.cc/en/Guide/Cores and use a good quality data USB cable (do not use a charging cable) to connect the board to the computer. Do not use USB 3.0 port or USB hub.
