Hi Folks,
I just received my Genuino Uno and installed the Arduino program on my Windows 10 PC. My Device Manager shows Genuino Uno (COM4) under Ports (COM & LPT) and I've selected that port in the Arduino program as well as the Arduino/Genuino Uno board.
As soon as I plug my USB cable into my computer, the L LED blinks on/off every 1 second. I opened the blink program, changed the 1000 to 300 or 2000 and click Upload, but I always get the below errors (verbose output).
Sketch uses 928 bytes (2%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM4 -b115200 -D -Uflash:w:C:\Users\erwim\AppData\Local\Temp\arduino_build_405482/Blink.ino.hex:i
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2f
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2f
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
I saw a post online talking about COM1 or COM3 but there's not enough detail there for me to figure out what happened.
How can I get uploading to work? Thanks!
Eric
