Hello,
I’ve read the notes for newbies like myself.
In trying to use the IDE (v1.18.13 under Ubuntu 20.04), I’m stumbling at the starting gate with a Nano33 BLE Sense and the Blink sketch. The Board & Port are correct because the Get Board Info returns the expected data. The error message for the Upload operation is:
Arduino: 1.8.13 (Linux), Board: "Arduino Nano 33 BLE"
Sketch uses 76356 bytes (7%) of program storage space. Maximum is 983040 bytes.
Global variables use 42160 bytes (16%) of dynamic memory, leaving 219984 bytes for local variables. Maximum is 262144 bytes.
java.io.IOException: Cannot run program "___REMOVE___/bossac": error=2, No such file or directory
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1048)
at java.lang.Runtime.exec(Runtime.java:620)
at java.lang.Runtime.exec(Runtime.java:485)
at processing.app.helpers.ProcessUtils.exec(ProcessUtils.java:11)
at cc.arduino.packages.Uploader.executeUploadCommand(Uploader.java:129)
at cc.arduino.packages.uploaders.SerialUploader.runCommand(SerialUploader.java:383)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:197)
at cc.arduino.UploaderUtils.upload(UploaderUtils.java:77)
at processing.app.SketchController.upload(SketchController.java:732)
at processing.app.SketchController.exportApplet(SketchController.java:703)
at processing.app.Editor$UploadHandler.run(Editor.java:2055)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.io.IOException: error=2, No such file or directory
at java.lang.UNIXProcess.forkAndExec(Native Method)
at java.lang.UNIXProcess.<init>(UNIXProcess.java:247)
at java.lang.ProcessImpl.start(ProcessImpl.java:134)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:1029)
... 11 more
An error occurred while uploading the sketch
option enabled in File -> Preferences.
The IDE works fine with UNO, MKR1000, Nano & ESP32xx boards. I cut and pasted the standard Blink sketch into the Web Editor and that permitted me to verify that the Nano33 BLE Sense board was fine.
Boards Manager informs me that I have v1.1.4 installed. Attempts to upgrade to v1.1.6 failed with the following message:
java.lang.NullPointerException
java.lang.RuntimeException: java.lang.NullPointerException
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:175)
Caused by: java.lang.NullPointerException
at cc.arduino.contributions.packages.ContributionInstaller.remove(ContributionInstaller.java:276)
at cc.arduino.contributions.packages.ui.ContributionManagerUI.lambda$onInstallPressed$2(ContributionManagerUI.java:170)
... 1 more
My only attempt at troubleshooting was to remove the Arduino IDE files and re-install a fresh download using the ./install.sh script.
Any advice will be gratefully applied for the resolution of this operator/user error. Many thanks.
Kind regards.
