I pulled out an old arduino to play with but I cannot get it working on my win 10 laptop. I am FAR from an expert on these. I played around with one years ago and got it working then but it was seemless. Not so much on this one.
I keep getting this error when I try to do the blink example. I checked the com and it is on arduino uno. I also tried to update the driver in the device manager but win 10 knows best and says the latest is installed. I have no idea what the problem is.
Thoughts?
Thanks,
Josh
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM3
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x50
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x50
avrdude done. Thank you.
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
