Cannot upload sketch to Arduino Uno R3 (SOLVED)
I recently bought an Arduino Uno R3 and followed this Arduino guide (http://arduino.cc/en/Guide/Windows) for installing the IDE and to upload the LED blink sketch. However, i always get "avrdude: stk500_getsync(): not in sync: resp=0x00".
During uploading of the sketch, only the RX LED blinks, never for the TX LED. The L LED (beside 13) just remains on always. I have read many online forums on this issue and done the following but to no avail:
-Changing USB cable
-Changing USB ports
-Reinstalling driver
-Restarting my laptop
-My board setting is at "Arduino Uno"
-My serial port number is correct when checked in Device Manager
Could it be a problem with my bootloader? Also, whenever i plug the board to my laptop, the ON LED and the L LED stays on permanently, even when I press the reset button. (Should this be the case?)
Needs more testing.
test 1: Run the "loopback test" to see if the board's USB serial converter is functioning. There is a sticky posting around here somewhere. If that fails then there is not much to can do about it other then get a new board.
test2: If the loopback test is good then you have either a bad 328P chip or it needs a new bootloader burned into the chip. To do a burn bootloader one needs either a IDE supported hardware programmer or another arduino board runnning the arduinoISP sketch which then becomes a 'hardware programmer'. Probably easiest solution if the test1 passes is to just buy a $5 replacement 328p chip that already has the proper Uno bootloader burned into it.
Hi, thanks for responding. The loopback test is good so I guess my problem is with the chip. I'll try to get back to my vendor for an exchange.
Apparently the bootloader could not be burned onto the chip and the vendor replaced it. :stuck_out_tongue:
