Cannot upload sketch
Hi all;
I'm trying to upload sketch on arduino mega 2560, but It wont.
Error:
Using Port : COM3
Using Programmer : wiring
Overriding Baud Rate : 115200
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done. Thank you.
An error occurred while uploading the sketch
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
  • Unplug your Arduino board from the computer.
  • Tools > Port
  • Note the ports, if any, listed in the menu.
  • Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  • Plug your Arduino board into the computer.
  • Tools > Port - The new port listed in the menu is your Arduino board.
All Checked
Everything is ok, No problem, But still don't upload
Try to upload EEPROM_clear, Blink and an empty sketch, all of them have the same result.
try using the Online Arduino IDE, follow the proper steps to install the Web Browser software; so your browser can upload your code to the board...
make sure you use a proper USB cable that can send power and data
all electronics are prone to electricity so be careful how you handle them
