Cannot upload sketches to arduino uno.
Hey everyone. This is my first time using arduino and first time posting onto the forums, but I've hit a bit of a snag and have no idea what is going wrong. I have been messing around with some basic sketches and whatnot with my new arduino uno, but recently I have not been able to upload to the board. It stopped suddenly and I don't know what I changed or did. Every forum I find that seems to have the same issue as me seems to have the solution as wrong port or board type in the IDE, but I am pretty sure mine are correct. I have tested on multiple computers and had the same issue.
Here is the error code i'm getting.
Arduino: 1.8.12 (Windows 10), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\Micha\AppData\Local\Temp\arduino_build_251012/Blink.ino.hex:i
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: Version 6.3-20190619
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM3
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x2a
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x2a
avrdude done.  Thank you.
option enabled in File -> Preferences.
Let me know what I can do or if any more info is needed. Again, I don't really know what I should be looking for. Thank yall.
(deleted)
