Cannot upload to Pro Mini
First time Arduino user here. I'm trying to upload a sketch to a Arduino Pro Mini via an FTDI Basic Breakout. I keep getting the following error message after the code compiles and attempts to upload. Any help would be great
Settings: Windows: 8.1 IDE: 1.6.1 Board: Arduino Pro or Pro Mini Processor ATmega328 (5V, 16MHz) Port: COM3
Error Message: Arduino: 1.6.1 (Windows 8.1), Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
Sketch uses 4,170 bytes (13%) of program storage space. Maximum is 30,720 bytes.
Global variables use 199 bytes (9%) of dynamic memory, leaving 1,849 bytes for local variables. Maximum is 2,048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x17
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xda
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfe
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x80
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x30
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x3e
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb0
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x82
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf2
This report would have more information with "Show verbose output during compilation" enabled in File > Preferences.
Either you are writing to the wrong com port or there is a wiring fault.
Start with the FTDI unplugged and check under tools->port. Then plug it in and check that there is a new port. Use that one if it is there, if not you have a driver issue that needs fixing.
Then check the wiring.
