This week I was trying to flash some new firmware to my FDL-3 Nerf Blaster (GitHub - projectfdl/FDL-3-Blaster), which uses a SparkFun Microview (https://www.sparkfun.com/sparkfun-microview-oled-arduino-module.html). I was being lazy and had the Microview programming board (https://www.sparkfun.com/sparkfun-microview-usb-programmer.html) plugged into the headers on the blaster and the Microview plugged into the programming board. After a test of the firmware I was flashing, I forgot to power off the blaster and left the switch in the on position. As soon as plugged in the USB extension cable to my computer the FTDI chip on the programming board burnt up.
I ordered a new programming board and Microview (just in case I burnt that up as well). When they came in I uploaded code to the new Microview with the new programming board, and that worked. So I tried uploading to the original Microview, and that did not work. I tried programming the new Microview again and it didn't work anymore. I tried a lot of things to get either Microview programmed, and I've probably forgotten most of what I did by now.
The error I'm getting is the classic:
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
Though I've seen multiple different values for the resp.
As it stands, I followed the Hookup Guide (MicroView Hookup Guide - SparkFun Learn), reinstalled the serial drivers, reinstalled the Arduino IDE v2.3.6 (including removing all Arduino related directories), re-burning the bootloader using my Arduino UNO (Reference #1) using Sparkfun's one and the Arduino UNO). I have tried a loopback test on the serial of the Microview (Reference #2) which passed. I have tried using two FTDI boards I had lying around (Reference #3), which didn't work. I've tried multiple USB ports on my computer, I tried without the USB extension cable, I tried quickly to use the Arduino IDE on my spare computer that runs Ubuntu. I've tried uploading the Microview examples from SparkFun. I tried shorting the reset pin to ground while trying to upload a sketch.
The only thing I have found to work is to use the Arduino UNO as an ISP programmer and the connections on the PCB inside the Microview's case. I can use avrdude on the command line as well as using the Arduino IDE "Upload Using a Programmer" function.
I don't know where to go next, I feel like I've tried everything and failed to get the Microview to accept a sketch through the serial. Any help would be amazing, as I would like to use the blaster on this coming Sunday.
