Cannot upload to Wemos D-1 Mini Lite - Need assistance please
My sketch compiles and uploads on the D-1 Mini but not the Mini lite. Never seen this error message before: Arduino: 1.8.4 (Windows 7), Board:
"WeMos D1 R2 & mini, 80 MHz, 921600, 4M (3M SPIFFS)"
Archiving built core (caching) in: C:\Users\User\AppData\Local\Temp\arduino_cache_418528\core\core_esp8266_esp8266_d1_mini_CpuFrequency_80,UploadSpeed_921600,FlashSize_4M3M_ff565c0521b3b290b9a28090db903bbb.a Sketch uses 270219 bytes (25%) of program storage space. Maximum is 1044464 bytes. Global variables use 34372 bytes (41%) of dynamic memory, leaving 47548 bytes for local variables. Maximum is 81920 bytes. warning: espcomm_sync failed error: espcomm_open failed error: espcomm_upload_mem failed error: espcomm_upload_mem failed
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Could this possibly be a cable issue? It just loaded on the Mini V2(I think).
This might be helpful: https://forum.wemos.cc/topic/274/how-to-flash-the-new-d1-mini-lite-with-arduino/8
pert: This might be helpful: https://forum.wemos.cc/topic/274/how-to-flash-the-new-d1-mini-lite-with-arduino/8
Pert; Yes, helpful. Have not been able to get it to work but I have a direction as to what I'm missing. Looks like I have to add some code to the boards.txt file. I did, still not working.
When I get some time. I will come back to this.
Thank you!
Glad to hear! Well if you run into any problems feel free to ask. I don't have any experience with the D1 Lite but I do know my way around a boards.txt file!
pert: Glad to hear! Well if you run into any problems feel free to ask. I don't have any experience with the D1 Lite but I do know my way around a boards.txt file!
I watched this video by Andeas Spiess: https://www.youtube.com/watch?v=JslhaM5FHZI Says to download the boards.txt file and replace it from github file. I did and it still does not work.
I have looked at the link you suggested in the Wemos forumn and made a few posts myself there. Deleted the esp boards altogether, then reinstalled it. Then added:
d1_mini_lite.name=WEMOS D1 mini Lite
d1_mini_lite.upload.tool=esptool
d1_mini_lite.upload.speed=921600
d1_mini_lite.upload.resetmethod=nodemcu
d1_mini_lite.upload.maximum_size=434160
d1_mini_lite.upload.maximum_data_size=81920
d1_mini_lite.upload.wait_for_upload_port=true
d1_mini_lite.serial.disableDTR=true
d1_mini_lite.serial.disableRTS=true
d1_mini_lite.build.mcu=esp8266
d1_mini_lite.build.f_cpu=80000000L
d1_mini_lite.build.board=ESP8266_WEMOS_D1MINI
d1_mini_lite.build.core=esp8266
d1_mini_lite.build.variant=d1_mini
d1_mini_lite.build.flash_mode=dout
d1_mini_lite.build.flash_freq=40
d1_mini_lite.build.spiffs_pagesize=256
d1_mini_lite.build.debug_port=
d1_mini_lite.build.debug_level=
d1_mini_lite.menu.CpuFrequency.80=80 MHz
d1_mini_lite.menu.CpuFrequency.80.build.f_cpu=80000000L
d1_mini_lite.menu.CpuFrequency.160=160 MHz
d1_mini_lite.menu.CpuFrequency.160.build.f_cpu=160000000L
d1_mini_lite.menu.UploadSpeed.921600=921600
d1_mini_lite.menu.UploadSpeed.921600.upload.speed=921600
d1_mini_lite.menu.UploadSpeed.115200=115200
d1_mini_lite.menu.UploadSpeed.115200.upload.speed=115200
d1_mini_lite.menu.UploadSpeed.9600=9600
d1_mini_lite.menu.UploadSpeed.9600.upload.speed=9600
d1_mini_lite.menu.UploadSpeed.57600=57600
d1_mini_lite.menu.UploadSpeed.57600.upload.speed=57600
d1_mini_lite.menu.UploadSpeed.256000.windows=256000
d1_mini_lite.menu.UploadSpeed.256000.upload.speed=256000
d1_mini_lite.menu.UploadSpeed.230400.linux=230400
d1_mini_lite.menu.UploadSpeed.230400.macosx=230400
d1_mini_lite.menu.UploadSpeed.230400.upload.speed=230400
d1_mini_lite.menu.UploadSpeed.460800.linux=460800
d1_mini_lite.menu.UploadSpeed.460800.macosx=460800
d1_mini_lite.menu.UploadSpeed.460800.upload.speed=460800
d1_mini_lite.menu.UploadSpeed.512000.windows=512000
d1_mini_lite.menu.UploadSpeed.512000.upload.speed=512000
d1_mini_lite.menu.FlashSize.1M512=1M (512K SPIFFS)
d1_mini_lite.menu.FlashSize.1M512.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M512.build.flash_ld=eagle.flash.1m512.ld
d1_mini_lite.menu.FlashSize.1M512.build.spiffs_start=0x7B000
d1_mini_lite.menu.FlashSize.1M512.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M512.build.spiffs_blocksize=8192
d1_mini_lite.menu.FlashSize.1M512.upload.maximum_size=499696
d1_mini_lite.menu.FlashSize.1M256=1M (256K SPIFFS)
d1_mini_lite.menu.FlashSize.1M256.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M256.build.flash_ld=eagle.flash.1m256.ld
d1_mini_lite.menu.FlashSize.1M256.build.spiffs_start=0xBB000
d1_mini_lite.menu.FlashSize.1M256.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M256.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M256.upload.maximum_size=761840
d1_mini_lite.menu.FlashSize.1M192=1M (192K SPIFFS)
d1_mini_lite.menu.FlashSize.1M192.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M192.build.flash_ld=eagle.flash.1m192.ld
d1_mini_lite.menu.FlashSize.1M192.build.spiffs_start=0xCB000
d1_mini_lite.menu.FlashSize.1M192.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M192.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M192.upload.maximum_size=827376
d1_mini_lite.menu.FlashSize.1M160=1M (160K SPIFFS)
d1_mini_lite.menu.FlashSize.1M160.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M160.build.flash_ld=eagle.flash.1m160.ld
d1_mini_lite.menu.FlashSize.1M160.build.spiffs_start=0xD3000
d1_mini_lite.menu.FlashSize.1M160.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M160.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M160.upload.maximum_size=860144
d1_mini_lite.menu.FlashSize.1M144=1M (144K SPIFFS)
d1_mini_lite.menu.FlashSize.1M144.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M144.build.flash_ld=eagle.flash.1m144.ld
d1_mini_lite.menu.FlashSize.1M144.build.spiffs_start=0xD7000
d1_mini_lite.menu.FlashSize.1M144.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M144.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M144.upload.maximum_size=876528
d1_mini_lite.menu.FlashSize.1M128=1M (128K SPIFFS)
d1_mini_lite.menu.FlashSize.1M128.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M128.build.flash_ld=eagle.flash.1m128.ld
d1_mini_lite.menu.FlashSize.1M128.build.spiffs_start=0xDB000
d1_mini_lite.menu.FlashSize.1M128.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M128.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M128.upload.maximum_size=892912
d1_mini_lite.menu.FlashSize.1M64=1M (64K SPIFFS)
d1_mini_lite.menu.FlashSize.1M64.build.flash_size=1M
d1_mini_lite.menu.FlashSize.1M64.build.flash_ld=eagle.flash.1m64.ld
d1_mini_lite.menu.FlashSize.1M64.build.spiffs_start=0xEB000
d1_mini_lite.menu.FlashSize.1M64.build.spiffs_end=0xFB000
d1_mini_lite.menu.FlashSize.1M64.build.spiffs_blocksize=4096
d1_mini_lite.menu.FlashSize.1M64.upload.maximum_size=958448
to the boards.txt file. The Wemos D-1 Mini Lite shows up in the "boards" list, so I don't understand why this is not uploading my sketch to the board. Boards manager URL: https://adafruit.github.io/arduino-board-index/package_adafruit_index.json https://github.com/esp8266/Arduino/releases/download/2.4.0-rc2/package_esp8266com_index.json
Here's the error code:
Arduino: 1.8.4 (Windows 7), Board: "WEMOS D1 mini Lite, 80 MHz, 921600, 1M (512K SPIFFS)"
Build options changed, rebuilding all
C:\Users\User\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar: unable to rename 'C:\Users\User\AppData\Local\Temp\arduino_build_186226/arduino.ar'; reason: File exists
exit status 1
Error compiling for board WEMOS D1 mini Lite.
Hoping you can shed some light on me. Thanks!
Nick
Often these "file exists" type errors are caused by your antivirus program. Try TEMPORARILY disabling the antivirus for a single compilation. If that solves the problem you will need to adjust the settings of your antivirus to whitelist the offending program/process/folder.
