Cannot use array values in an if statement
Hello everyone, I'm currently working on a project where I have to use the MPU6050 and what I tried to do was use the I2Cdevlib code to allow my MPU6050 to give stable enough values. Now I'm trying to create parameters to it, so I can write what I want in an LCD according to the position of the gyroscope but for some reason, it does not recognize the statement and does not write anything at all. This is the code I'm trying to use:
#include "MPU6050_6Axis_MotionApps20.h"
#include <LiquidCrystal.h>
LiquidCrystal lcd(3,2,11,9,7,5);
MPU6050 mpu;
uint8_t mpuIntStatus;
uint16_t packetSize;
uint16_t fifoCount;
uint8_t fifoBuffer[64];
Quaternion q;
VectorFloat gravity;
float ypr[3];
#define contra 9
#define bri 10
//Código do MPU6050.
Wire.begin();
lcd.begin(16, 2);
pinMode(contra, OUTPUT);
pinMode(bri, OUTPUT);
digitalWrite(contra, LOW);
analogWrite(bri, 255);
lcd.print("Inete TEAC16");
lcd.setCursor(0, 1);
TWBR = 24;
mpu.initialize();
mpu.dmpInitialize();
mpu.setXAccelOffset(-1343);
mpu.setYAccelOffset(-1155);
mpu.setZAccelOffset(1033);
mpu.setXGyroOffset(19);
mpu.setYGyroOffset(-27);
mpu.setZGyroOffset(16);
mpu.setDMPEnabled(true);
packetSize = mpu.dmpGetFIFOPacketSize();
//Por algum motivo se utilizar "9600" aparece erro "FIFO overflow!".
//COMENTAR_OFICIAL
void gyro()
while (fifoCount < packetSize) {
//do stuff
fifoCount = mpu.getFIFOCount();
if (fifoCount == 1024) mpu.resetFIFO();
else {
mpu.getFIFOBytes(fifoBuffer, packetSize);
mpu.resetFIFO();
fifoCount -= packetSize;
mpu.dmpGetQuaternion(&q, fifoBuffer);
mpu.dmpGetGravity(&gravity, &q);
mpu.dmpGetYawPitchRoll(ypr, &q, &gravity);
void screen()
Serial.print(" ||p = "); Serial.print(ypr[1]*180/PI);
Serial.print(" r = "); Serial.print(ypr[2]*180/PI);
delay(200);
gyro();
screen();
if(ypr[1]>=40) //Tried this basic task, reading if the value was above 40 and eventhough it was it did not // write anything at all
lcd.setCursor(0,2);
lcd.print("Letter: A");
Serial.println("Letter A");
  lcd.begin(16, 2);
    lcd.setCursor(0, 2);
How many rows are there on the LCD ?
How are they numbered, I wonder ?
It's a 16x2 LCD display, 16 columns 2 lines
TEAC:
Yes, but how are the lines numbered ?
They are numbered as 1 and 2. The counting does not start on 0
Why not try
Serial.println( ypr[1], 6 );
 lcd.setCursor(0,2);
to see what ypr[1] actually is?
Most likely, you may find that, basically, 40 is not 40.0f
Why does column numbering start at 0, then?
TEAC:
Which LiquidCrystal library are you using ?
