I am trying to use my Arduino Duemilanove to program a Attiny 85 microcontroller. I am running Arduino on my Windows 7 Toshiba laptop. I have done this before with a DIP in Arduino version 0022 but cannot seem to get it to work now.
I followed this tutorial: http://hlt.media.mit.edu/?p=1706
I connected all the pins (PWR, GND, SCLK, MISO, etc...) to the appropriate arduino pins and to the attiny through a header on the board it is affixed to. I double checked all the connections but still cannot get the chip to program. I tried to program it from arduino 0022 and 1.0 but to no avail.
The ISP programming sketch uploads fine but when I try to upload the code to the attiny this is the error message I get Arduino 1.0:
Binary sketch size: 818 bytes (of a 8192 byte maximum)
avrdude: please define PAGEL and BS2 signals in the configuration file for part ATtiny85
avrdude: stk500_program_enable(): protocol error, expect=0x14, resp=0x50
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
If someone could point me to a solution I would be greatly appreciative.
-Peter
