Cannot use the three values "time1", "humidity", "temperature" as input for loop
The three values time1, humidity, temperature in the void timebase cannot be used to sub into the void loop. I used them for limits for the void loop, but it doesn't work.
This is my code, words in // // can be ignored
#include <MsTimer2.h>
// Arduino Playground - MsTimer2
#include <SoftwareSerial.h>
#define txPin 1
#define heater 10
#define fan 11 // fan connected to PWM pin 9
#define motor 12 // motor connected to PWM pin 10
SoftwareSerial LCD = SoftwareSerial(0, txPin);
// since the LCD does not send data back to the Arduino, we should only
int time1=30;
int temperature=60;
int humidity=60;
const int LCDdelay=2; // minimum 2, increase if LCD is unstable
int ms200 = 0, seconds = 0, minutes = 0;
// to store the time
boolean right = 0, up = 0, left = 0, down = 0, ok = 0, humi=0, humi2=0, reset=0;
boolean rightReleased = 1, upReleased = 1, leftReleased = 1, downReleased
= 1, okReleased = 1, humireleased=0, humireleased2=0, resetreleased=0;
// to store the status of the 5 buttons
void clearLCD(){
LCD.write(0xFE); //command flag
LCD.write(0x51); //clear command.
delay(LCDdelay);
void serCommand() { //a general function to call the command flag for
LCD.write(0xFE);
void backlite(char x){
LCD.write(0xFE);
LCD.write(0x53);
LCD.write(x);
delay(1);
void timebase() {
// this function is called the Interrupt Service Routine (ISR)
// It executes every 0.2 seconds, triggered by Timer2 interrupt
ms200++;
if (ms200 > 4){
seconds++;
ms200 = 0;
if (seconds > 59){
minutes++;
seconds = 0;
} // increments the time in minutes, seconds and 0.2 seconds
// put code to read buttons and sensors here,
// be sure to debounce, cater for press and hold,
// press and repeat, etc.
if (digitalRead(2)){ //if right button is not pressed (active low)
right = 0;
rightReleased = 1;
else{ // if right button is pressed
if (rightReleased){ // if the button is previously released
right = 1;
rightReleased = 0; // so that it does not repeat if press & hold
if (digitalRead(3)){ //if ok button is not pressed (active low)
ok = 0;
okReleased = 1;
else{
if (okReleased){ // if the button is previously released
ok = 1;
okReleased = 0; // so that it does not repeat if press & hold
if (digitalRead(4)){ //if up button is not pressed (active low)
up = 0;
upReleased = 1;
else{
if (upReleased){ // if the button is previously released
up = 1;
upReleased = 0; // so that it does not repeat if press & hold
if (digitalRead(5)){ //if down button is not pressed (active low)
down = 0;
downReleased = 1;
else{
if (downReleased){ // if the button is previously released
down = 1;
downReleased = 0; // so that it does not repeat if press & hold
if (digitalRead(7)){ //if down button is not pressed (active low)
humi = 0;
humireleased = 1;
else{
if (humireleased){ // if the button is previously released
humi = 1;
humireleased = 0; // so that it does not repeat if press & hold
if (digitalRead(8)){ //if down button is not pressed (active low)
humi2 = 0;
humireleased2 = 1;
else{
if (humireleased2){ // if the button is previously released
humi2 = 1;
humireleased2 = 0; // so that it does not repeat if press & hold
if (digitalRead(9)){ //if down button is not pressed (active low)
reset = 0;
resetreleased = 1;
else{
if (resetreleased){ // if the button is previously released
reset = 1;
resetreleased = 0; // so that it does not repeat if press & hold
if (digitalRead(6)){ //if left button is not pressed (active low)
left = 0;
leftReleased = 1;
else{
if (leftReleased){ // if the button is previously released
left = 1;
leftReleased = 0; // so that it does not repeat if press & hold
// put code to refresh the LCD or indicator lights here, e.g.:
clearLCD();
delay(LCDdelay);
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(5);
LCD.print("Time");
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(10);
LCD.print("Temp");
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(15);
LCD.print("Humi");
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(46);
LCD.print(time1);
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(51);
LCD.print(temperature);
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(56);
LCD.print(humidity);
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(89);
LCD.print("min");
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(95);
LCD.print("C");
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(100);
LCD.print("%");
if (right){
//Change Cursor position to Line 2 column 13
temperature=temperature-1;
if (ok){temperature=temperature+1;
//Change Cursor position to Line 2 column 10
//LCD.write(0xFE);
//LCD.write(0x45);
//LCD.write(49);
//LCD.print("OK");
//delay(LCDdelay);
if (up){
time1=time1+5;
if (down){
time1=time1-5;
if(humi){
humidity=humidity-1;
if(humi2){
humidity=humidity+1;
if(reset){
time1=30;
temperature=60;
humidity=60;
if (left){
//Change Cursor position to Line 2 column 4
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(40);
LCD.print("START");
// put the various setup code here
pinMode(txPin, OUTPUT);
pinMode(2, INPUT_PULLUP); // right button
pinMode(3, INPUT_PULLUP); // ok button
pinMode(4, INPUT_PULLUP); // up button
pinMode(5, INPUT_PULLUP); // down button
pinMode(6, INPUT_PULLUP); // left button
pinMode(7, INPUT_PULLUP);
pinMode(8, INPUT_PULLUP);
pinMode(9, INPUT_PULLUP);
pinMode(10, OUTPUT);
pinMode(11, OUTPUT);
pinMode(12, OUTPUT);
//Set Arduino serial baud rate to 9600kbps
LCD.begin(9600);
//If LCD is not responding correctly,
//try other baud rates: 300,1200,2400,14400,19200,57600,115200
backlite(2); // acceptable values 1 to 8
//Show LCD's baud rate
LCD.write(0xFE);
LCD.write(0x71);
delay(LCDdelay);
//Change Cursor position to line 1 column 1
LCD.write(0xFE);
LCD.write(0x45);
LCD.write(0x40);
LCD.print("Newhaven Display");
delay(LCDdelay);
// Timer2 interrupt every 0.2 seconds
MsTimer2::set(200, timebase);
// run the interrupt service routine (ISR) timebase()
// every 200 milliseconds
MsTimer2::start(); // start the ISR
if(left){
for (int fadeValue = 0 ; fadeValue <= humidity; fadeValue += 5) {
// sets the value (range from 0 to 255):
analogWrite(fan, fadeValue);
// wait for 30 milliseconds to see the dimming effect
delay(30);
for (int fadeValue = 0 ; fadeValue <= time1; fadeValue += 5) {
analogWrite(motor, fadeValue);
delay(30);
digitalWrite(heater, HIGH);
delay(5000);
digitalWrite(heater, LOW);
// fade out from max to min in increments of 5 points:
for (int fadeValue = time1 ; fadeValue >= 0; fadeValue -= 5) {
delay(30);
for (int fadeValue = humidity ; fadeValue >= 0; fadeValue -= 5) {
delay(30);
delay(5000);}
Variables used both inside and outside of an ISR need to have the word volatile before the variable type when they are declared.
Ok now let’s get things straight. First of all read the how to use this forum sticky post to find out how to post code here. Then use the edit menu under your post and put code tags in.
Next do not add the word void when talking about function. For example it is the loop function NOT the void loop. Void is simply telling the compiler that this function returns no variables. It is in no way part of the name and is very annoying to read and is like a big sign that says “I don’t know what I am doing”. Which judging by the way you have five second delays sprinkled in the loop function, you don’t.
Finally when you say won’t work, what do you mean?
You get a compiler error?
The code runs but these variables have no effect?
You should say what you expect the code to do and what it actually does.
Right, first things first.
Please go and read the instructions, then go back and modify your post (use the "More --> Modify" option to the bottom right of the post) to mark up the code (but it needs to be the complete code) as such so we can examine it conveniently and accurately. Do not post a ".ino" file as an attachment - that means that you are expecting people to actually load it to their IDE to look at it and that is extra unnecessary labour. In fact, attachments do not always show properly on different operating systems.
If you do not mark it up as code, the code you post could well be garbled (notice the "smiley" you now have :grinning: ) and is certainly anything but easy to read, so you will find little enthusiasm for assistance with it.
Note: Also mark up any data in the same way. This includes error output that you get from the IDE.
And - before you post any code, use "Auto Format" in the Tools menu of the IDE to properly present the code.
Try and avoid unnecessary white space (blank lines). You should only use these to separate functional blocks of code.
