Cannot view output of Serial.println() inside setup() routine
I have searched for "Arduino hello world" projects and they all write to serial in the setup() routine like this:
  Serial.println("Hello World!");
(for example on arduinogetstarted.com or instructables.com)
The problem is that when uploading, the serial window in the arduino IDE gets closed.
So you will never see the "Hello World!".
I received my Arduino today so everything is new to me.
But I wonder how this hello world ever worked?
does it have CH340 as USB chip? CH340 has some start delay. try to add delay(500); after Serial.begin
Juraj:
It's a Arduino micro. I have debian linux.
I've read, that the programmer needs the serial window so it closes when you upload.
smorra:
To be more accurate, it needs the serial port. Any time you re-open the serial window, it should reset the Arduino, and the program will run again from the beginning. Then you will see, "Hello World".
Some programs have
while (!Serial);
at the beginning to wait for the USB serial to come on line.
smorra:
on Micro the MCU has native USB. to wait until it builds the connection you have to add
while (!Serial);
don't forget to remove it if you want to run a sketch without USB connection
