Cannot write serial Data to Arduino
Hi ,
i set up a serial communication between my Java environment and Arduino.
I made an easy program that write 1 to the Java console if i push a button on the Arduino and it works very good
and it is also very fast. The problem is on the other way around, i am trying to write a String from Java
to Arduino.
Here is the java code to write bytes:
public void writeSerial(String st)
        try {
        	serialOut.write(st.getBytes());
        } catch (IOException e) {}
Here i am just writing a String to the Serial Port.
The Arduino code to read the String:
    byte byteAvailable = Serial.available();
    if(Serial.available() > 0)
    lcd.setCursor(1,2);
    lcd.print("Available");
What i am doing in the Arduino code is to write "Available " to an lcd screen
if i have data available in the serial port.
The main.java class will be something very easy like:
public class main {
	public static void main(String args[]) throws Exception
		serialCom test = new serialCom();
		test.begin();
		test.writeSerial("hello");
the begin() function is where i set up the port.
In this way i never get anything on my lcd screen unless i replace
with
while(true)
in the main function.
If i keep writing data to the serial port then i actually receive it. But i really need to have something much faster.
Here is how i set up the port..
public void begin() throws Exception
		String serialMessage = "c" ;
		CommPortIdentifier port = CommPortIdentifier.getPortIdentifier( "/dev/ttyACM2");
		CommPort commPort = port.open(this.getClass().getName(),2000);
        serialPort = (SerialPort) commPort;
        //setting up the port. ;?ake sure that thew communication speed is the same in the Arduino IDE
        serialPort.setSerialPortParams(115200, SerialPort.DATABITS_8, SerialPort.STOPBITS_1, SerialPort.PARITY_NONE);
        serialIn=serialPort.getInputStream();
		serialOut=serialPort.getOutputStream();
		serialReader = new BufferedReader( new InputStreamReader(serialIn) );
        serialPort.addEventListener(this);
        serialPort.notifyOnDataAvailable(true);
Anyone can help?
thank you
I find Java code particularly impenetrable but I have written code in JRuby (which uses the JVM) to communicate with my Uno.
A common problem for beginners is that their PC code doesn't allow for the time it takes the Arduino to reset when the Serial port is opened. It's a good idea for the Arduino to send a short message to the PC from setup() and for the PC code to wait for that before sending anything.
This demo illustrates the technique and I think it includes JRuby code as well as Python.
...R
that helped a lot!!
As you said i didn't give time enough to Arduino to set up the connectionm, that's how i modified the Java code:
public class main {
		test.begin();
               Thread.sleep(2000);
		test.writetoport("hello");
Thread.sleep(2000) stops everything for 2 seconds then it writes "hello" to the serial port.
This solution works very well.
Thank you
I assume serialCom test = new serialCom(); is what opens the serial port
I don't know what test.begin() does and it may well be appropriate to run it in parallel with the Arduino resetting.
I would expect 2 seconds to be too short and something closer to 10 might be needed. It may be that the code in test.begin() is providing some additional waiting time.
...R
giulianoAI:
Which Arduino?
How to use this forum
