hi
i have this motor AK80-80_AK Series Dynamical Modular_Exoskeleton Robot_CubeMars - Professional and Reliable manufacturer for robot actuators and frameless motors connected to mcp2515 Module Cs to pin 10
Si to pin 11
So to pin 12
Suck to pin 13
H CAN from the mcp2515 to H motor
L CAN from the mcp2515 to L motor
And I use termination 120 oham
// demo: CAN-BUS, send data
#include <mcp_can.h>
#include "mcp2515_can.h"
#include <SPI.h>
//SAMD core//
#ifdef ARDUINO_SAMD_VARIANT_COMPLIANCE
#define SERIAL SerialUSB
#else
#endif
//Value Limits
#define P_MIN -95.5f
#define P_MAX 95.5f
#define V_MIN -25.64f
#define V_MAX 25.64f
#define KP_MIN 0.0f
#define KP_MAX 500.0f
#define KD_MIN 0.0f
#define KD_MAX 5.0f
#define T_MIN -18.0f
#define T_MAX 18.0f
//Set values
float p_in = 0.0f;
float v_in = 20.0f;
float kp_in = 10.0f;
float kd_in = 1.0f;
float t_in = 12.0f;
//measured values
float p_out = 0.0f;
float v_out = 0.0f;
float t_out = 0.0f;
const int SPI_CS_PIN = 10;
mcp2515_can CAN(SPI_CS_PIN);
{ Serial.begin(115200);
Serial.println("setup");
while (CAN_OK != CAN.begin(CAN_1000KBPS))
Serial.println("CAN BUS Shield init fail");
Serial.println("Init CAN BUS Shield again");
delay(100);
Serial.println("CAN BUS Shield init ok!");
//Initialize pins as necessary
pinMode(2, INPUT);
long previousMillis = 0;
//do something
//Enable
EnterMotorMode();
Serial.println("Enabled");
//UP
float p_step = 0.1;
Serial.println("UP");
p_in = p_in + p_step;
//Down
Serial.println("DOWN");
p_in = p_in - p_step;
//Exit
ExitMotorMode();
Serial.println("Disabled");
pack_cmd();
if (CAN_MSGAVAIL == CAN.checkReceive())
Serial.println("received");
unpack_reply();
Serial.print("\t");
Serial.print(p_out);
Serial.print("\t");
Serial.print(v_out);
Serial.print("\t");
Serial.println(t_out);
delay(10);
void EnterMotorMode()
//Enter Motor Mode (enable)
byte buf[8];
buf[0] = 0xFF;
buf[1] = 0xFF;
buf[2] = 0xFF;
buf[3] = 0xFF;
buf[4] = 0xFF;
buf[5] = 0xFF;
buf[6] = 0xFF;
buf[7] = 0xFC;
for (int i = 0; i < sizeof(buf); i++)
Serial.println(buf[i], HEX);
CAN.sendMsgBuf(0x01, 0, 8, buf);
delay(50);
void ExitMotorMode()
//Exit Motor Mode (enable)
byte buf[8];
buf[0] = 0xFF;
buf[1] = 0xFF;
buf[2] = 0xFF;
buf[3] = 0xFF;
buf[4] = 0xFF;
buf[5] = 0xFF;
buf[6] = 0xFF;
buf[7] = 0xFD;
delay(50);
delay(50);
return 1;
void Zero()
byte buf[8];
buf[0] = 0xFF;
buf[1] = 0xFF;
buf[2] = 0xFF;
buf[3] = 0xFF;
buf[4] = 0xFF;
buf[5] = 0xFF;
buf[6] = 0xFF;
buf[7] = 0xFE;
delay(50);
void pack_cmd()
byte buf[8];
/// CAN Command Packet Structure ///
/// 16 bit position command, between -4*pi and 4*pi
/// 12 bit kp, between 0 and 500 N-m/rad
/// 12 bit kd, between 0 and 100 N-m*s/rad
/// 12 bit feed forward torque, between -18 and 18 N-m
/// CAN Packet is 8 8-bit words
/// Formatted as follows. For each quantity, bit 0 is LSB
/// 0: [position[15-8]]
/// 1: [position[7-0]]
/// 2: [velocity[11-4]]
/// 3: [velocity[0-3], kp[11-8]]
/// 4: [kp[7-0]]
/// 5: [kd[11-4]]
/// 6: [Kd[3-0], torque[11-8]]
/// 7: [torque[7-0]]
//Serial.println("packing");
//delay(20);
///limit data to be within bounds ///
float p_des = constrain(p_in, P_MIN, P_MAX);
float v_des = constrain(v_in, V_MIN, V_MAX);
float kp = constrain(kp_in, KP_MIN, KP_MAX);
float kd = constrain(kd_in, KD_MIN, KD_MAX);
float t_ff = constrain(t_in, T_MIN, T_MAX);
//convert floats to unsigned ints ///
unsigned int p_int = float_to_uint(p_des, P_MIN, P_MAX, 16);
Serial.println(p_int);
//delay(10);
unsigned int v_int = float_to_uint(v_des, V_MIN, V_MAX, 12);
//Serial.println(v_int, HEX);
//delay(10);
unsigned int kp_int = float_to_uint(kp, KP_MIN, KP_MAX, 12);
//Serial.println(kp_int, HEX);
//delay(10);
unsigned int kd_int = float_to_uint(kd, KD_MIN, KD_MAX, 12);
//Serial.println(kd_int, HEX);
//delay(10);
unsigned int t_int = float_to_uint(t_ff, T_MIN, T_MAX, 12);
//Serial.println(t_int, HEX);
//delay(10);
//pack ints into the can buffer ///
buf[0] = p_int >> 8;
buf[1] = p_int & 0xFF;
buf[2] = v_int >> 4;
buf[3] = ((v_int & 0xF) << 4) | (kp_int >> 8);
buf[4] = kp_int & 0xFF;
buf[5] = kd_int >> 4;
buf[6] = ((kd_int & 0xF) << 4) | (t_int >> 8);
buf[7] = t_int & 0xFF;
/* buf[0] = 0x01;
buf[1] = p_int>>8;
buf[2] = p_int&0xFF;
buf[3] = v_int>>4;
buf[4] = ((v_int&0xF)<<4)|(t_int>>8);
buf[5] = t_int&0xFF;
CAN.sendMsgBuf(0x01, 0, 6, buf);*/
delay(10);
void unpack_reply()
///CAN Reply Packet Structure ///
/// 16 bit position, between -4*pi and 4*pi
/// 12 bit velocity, between -30 and +30 rad/s
/// 12 bit current, between -40 and +40;
/// CAN Packet is 5 8-bit words
/// 1: [postion[7-0]
/// 3: [velocity[3-0], current[11-8]]
/// 4: [current[7-0]]
Serial.println("unpacking");
byte len = 0;
byte buf[8];
CAN.readMsgBuf(&len, buf);
unsigned long canId = CAN.getCanId();
/// unpacks ints from CAN buffer ///
unsigned int id = buf[0];
unsigned int p_int = (buf[1] << 8) | buf[2];
//Serial.println(p_int);
//delay(10);
unsigned int v_int = (buf[3] << 4) | (buf[4] >> 4);
//Serial.println(v_int);
//delay(10);
unsigned int i_int = ((buf[4] & 0xF) << 8) | buf[5];
//Serial.println(i_int);
//delay(10);
/// converts uints to floats ///
p_out = uint_to_float(p_int, P_MIN, P_MAX, 16);
v_out = uint_to_float(v_int, V_MIN, V_MAX, 12);
t_out = uint_to_float(i_int, T_MIN, T_MAX, 12);
unsigned int float_to_uint(float x, float x_min, float x_max, int bit)
{ /// converts a float to an unsigned int, given range and number of bits ///
//Serial.println("conv2");
//Serial.println(x);
//delay(20);
float span = x_max - x_min;
float offset = x_min;
//Serial.println(offset);
unsigned int pgg = 0;
if (bit == 12)
unsigned int pgg = (x - offset) * 4095 / span;
//Serial.println(pgg);
return pgg;
if (bit == 16)
unsigned int pgg = (x - offset) * 65535 / span;
return pgg;
unsigned int uint_to_float(unsigned int x_int, float x_min, float x_max, int bit)
{ /// converts an unsigned int to a float, given range and number of bits ///
//Serial.println("conv1");
//Serial.println(x_int);
//Serial.print(x_min);
//delay(20);
if (bit == 12)
float pgg = span * (x_int / 4095);
pgg = pgg + offset;
//delay(50);
if (bit == 16)
float pgg = span * (x_int / 65535);
pgg = pgg + offset;
//delay(50);
return pgg;
// END FILE
this my code and try to make the motor move step forward and other backward , but nothing happen for motor and no movement at all , anyone have any idea why ?
Thank you in advance
