Can't able to send Http Request using ESP8266
I have Arduino Uno and for Wifi ESP8266
My ESP8266 Firmware is
AT+GMR
AT version:0.40.0.0(Aug 8 2015 14:45:58)
SDK version:1.3.0
Ai-Thinker Technology Co.,Ltd.
Build:1.3.0.2 Sep 11 2015 11:48:04
baund = 115200
Both NL & CR
Server -- www.linysoft.com
Weblink i want to send -- http://www.linysoft.com/arduino/?light=off OR http://www.linysoft.com/arduino/?light=on
according to link i can get result ==> on or ==> off on page
http://www.linysoft.com/arduino/light.json
Now i want to send Http Request(Weblink - http://www.linysoft.com/arduino/?light=on)
so it can write according on that link "on" in light.json page.
Now AT command i am sedding (My wifi module is connected to my wifi automatically)
WIFI CONNECTED
WIFI GOT IP
AT+CWMODE=1
OK
AT+CIPMUX=1
OK
AT+CIPSTART=0,"TCP","www.linysoft.com",80
0,CONNECT
OK
AT+CIPSEND=0,200
OK
Now here i am getting problem after this >
i can't able to send
GET /arduino/?light=on
I also tried GET /arduino/?light=on HTTP/1.0\r\n
after putting this line on textbox then i press Enter button or Send Button nothing will happen
It will stuck on here > for some time
and than it shows me
OK
0,CLOSED
Pin Connection
ARDUINO UNO ESP8266
RX --------------> TX
TX --------------> RX
VCC--------------> 3.3
CH_PD ----------> 3.3
GND -------------> GND
Try it with another carriage return and line feed:
GET /arduino/?light=on HTTP/1.0\r\n\r\n
The first one indicates the end of the one line you send.
The second one (an empty line) indicates the end of all your headers, i.e. the end of your request.
That often happens when you confuse the device by trying to use the serial port to communicate with it AND with the PC. Get the device off of the hardware serial port.
