Hello guys,
I have a problem with my SD-module and my Due. When I try to use it with the sdfat library i can´t access the sd-card. I always get the error message:
"Can't access SD card. Do not reformat. SD errorCode: 0X50,0X0"
There are two strange things about this, I have used the sd module bevore with the Due the second thing is that, when I use the same shield with the same code and the "same" wiring on an Mega2560 there
aren´t any problems. I wire the board over the SPI on the Due and over the ICSP on the Mega.
Now my question: Do you think the chip of my due is probably damaged or could it be another problem?
Hope someone of you can help me.
