Can't access the value of the i-th element of array
Hello everyone,
I am having a problem with accesing the value of i-th element of array in the code below:
int i=0;
int pulse_x[100];
int pulse_y[100];
int pulse_z[100];
void loop(){
    pulse_x[i]=i+1;
    pulse_y[i]=i+2;
    pulse_z[i]=i+3;
    i = i + 1;
    char str[20];
    sprintf(str, "%d,%d,%d,%d", i, pulse_x[i], pulse_y[i], pulse_z[i]);
    Serial.println(str);
    Serial.print(i);
    Serial.print(' ');
    Serial.print(pulse_x[i]);
    Serial.print(' ');
    Serial.print(pulse_y[i]);
    Serial.print(' ');
    Serial.print(pulse_z[i]);
    Serial.println(" a");
    delay(100);
    if (i==100) exit(0);
The value of the whole array return 0 in Serial monitor. How can I get the right value? Thank you guys.
You are incrementing i too early. Do it after printing the values otherwise it points to the next array element rather than the current one
if the size of the array is 100, what is the maximum index value?
exit(0) is a strange way to end a loop… normally you would:
int pulse_x[100];
int pulse_y[100];
int pulse_z[100];
char str[20];
void setup(){
  for (int i=0; i < 100;  i = i + 1)
    pulse_x[i]=i+1;
    pulse_y[i]=i+2;
    pulse_z[i]=i+3;
    Serial.print(i);
    Serial.print(' ');
    Serial.print(' ');
    Serial.print(' ');
    delay(100);
void loop(){ }
UKHeliBob:
OMG I'm so stupid, thank you :o :o :o
Not stupid, just human
the "off by 1" bug is the most common
