Can't add libraries to Arduino IDE
Hi everyone,
I have a Toshiba laptop running Ubuntu 12.04. I have installed the Arduino IDE using the Ubuntu Software Centre and it works fine for creating projects and uploading to my Arduino. However I recently wanted to add a new library that I downloaded and I don't have the "add libraries" option under Import Libraries. I get a list of Libraries but no option to add one. I have searched online and not seen any solution. I have tried removing and reinstalling the software.
Please help.
Thanks
Darren
you can copy the library also manually.
this link - http://arduino.cc/en/Guide/Libraries - should help you
Thank you for the response Rob.
I tried manually copying the folder containing the library like they say in the instructions. I still do not have the new library in the list of available libraries in the drop down menu. Will the library still work if it doesn't appear in the drop down menu but is saved in the proper location?
Thanks
Darren
Darkwing52:
The repos used by Linux distributions are usually old. Download the latest 1.0.x (for Uno, Mega, and Variants) or 1.5.x (Yun, Due) and you'll have the Add Library option.
Darkwing52:
You need to copy it into your sketchbook directory, under a directory called "libraries" (all lower case). You can find your sketchbook by looking at the Arduino IDE preferences.
Once there, you need to restart the IDE. If it isn't showing up, either you didn't copy it correctly (not the whole directory, didn't change the name of something in the README, etc) or it is in the wrong place.
Your comment James about repos for Linux distributions got me digging deeper. I had installed from the Ubuntu Software Centre and it must have been an older version. I found on the playground wiki this line to execute in terminal
Ubuntu 12.04 and newer
sudo apt-get update && sudo apt-get install arduino arduino-core
After I downloaded this the Arduino IDE 1.0.6 worked and the "add library" was there.
Thanks for your help.
Darren
