Cant arm my esc with arduino. Please help with code.
Hi there, I cant arm my esc with code. To arm it the manual sais I have to pull the throttle back. All i want to do is control the motor's speed.
Please can someone help
The throttle must be at "off" for several seconds before your ESC will arm. You should get a series of beeps when it is armed. Usually a 1000us pulse for the arming period will allow it to arm. Mine does.
Is this the same query as http://forum.arduino.cc/index.php?topic=428133.msg2951082#msg2951082
Yeh sorry it is. I couldnt get it to work dont know what i am doing wrong. Here is the code
#include <Servo.h>
Servo myservo;
int pos = 0;
myservo.attach(9,600,2250); // attaches the servo on pin 9 to the servo object
myservo.write(50);
myservo.write(60);
myservo.write(70);
myservo.write(80);
myservo.write(90);
myservo.write(100);
for(pos = 0; pos < 179; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable ‘pos’
delay(15); // waits 15ms for the servo to reach the position
for(pos = 179; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
delay(10000);
myservo.write(50);
myservo.write(50);
myservo.write(60);
myservo.write(70);
myservo.write(80);
myservo.write(90);
myservo.write(100);
delay(10000);
myservo.write(50);
  myservo.write(0);
  delay(5000);
Please use code tags. It makes your code more readable.
Insert myServo.write(0); before myServo.attach(); Insert delay(1000); after myServo.attach(); If that doesn't work, increase the delay.
would this work. just dont know how to set the speed to increase and decrease
#include <Servo.h>
Servo motor1;
void arm(){
motor1.write(0);
delay(5000);
motor1.attach(9);
arm();
motor1.write(86);
