Can't burn sketch with arduino-0011
I've been using arduino-0009 without any problem. Today i've installed 0011 and problems have come.
I can't burn any sketch, i get this error always:
Binary sketch size: 3184 bytes (of a 14336 byte maximum)
avrdude: Yikes!  Invalid device signature.
         Double check connections and try again, or use -F to override
         this check.
The same sketch can be burn with 0009 version.
Help please!
Are you sure you have chosen the right board in the tools -> microcontroller menu? I don't think each version of the IDE remembers your settings from previous versions
yeah, arduino is selected :-/
i really don't know why it works on arduino-0009 and not in 0011
grrrr
Yep but is it the RIGHT arduino?
Serial, NG, Decimelia, Lilypad etc...
sure, it's decimilla.
I'll stick to 0009 since it's working :S
solved in this another thread: http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1202087650
it was an amd64 related problem, edited source code to add a "-F" flag and compiled again.
working right now :slight_smile:
