what program is running on the PC
if I run this UDP chat program on a Nano with a ENC28j60
// UDP chat program using ENC28J60 tested on UNO and Nano
// **** change IP addresses and ports to suit requirements *****
#include <EthernetENC.h> // for ENC28J60
#include <EthernetUdp.h> // for UDP
// ***** IP of this machine and remote machine *********
IPAddress localIP; // these will be read from the keyboard
IPAddress remoteIP;
// Enter a MAC address
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
unsigned int localPort = 10000; // local port to listen on
unsigned int remotePort = 10000; // remote port to transmiit too
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
while (!Serial)
Serial.println("\nEthernet UDP chat program");
// Check for Ethernet hardware present
// You can use Ethernet.init(pin) to configure the CS pin
Ethernet.init(10); // Most Arduino shields
//Ethernet.init(5); // MKR ETH Shield
//Ethernet.init(0); // Teensy 2.0
//Ethernet.init(20); // Teensy++ 2.0
//Ethernet.init(15); // ESP8266 with Adafruit FeatherWing Ethernet
//Ethernet.init(33); // ESP32 with Adafruit FeatherWing Ethernet
localIP = getIPaddress("\nenter local IP address (e.g. 192.168.1.176)? ");
Serial.print("\nRemote ");
//displayMACaddress(mac);
mac[5] = localIP[3]; // change default MAC address
// start the Ethernet
Ethernet.begin(mac, localIP);
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
Udp.begin(localPort); // start UDP
Serial.print("Ethernet UDP started ");
displayIPaddress(localIP, localPort);
// get remote IP address
remoteIP = getIPaddress("\nenter remote IP address (e.g. 192.168.1.176)? ");
displayIPaddress(remoteIP, remotePort);
// if Serial text entered transmit as a datagram
if (Serial.available()) {
char text[20] = { 0 };
Serial.readBytesUntil('\n', text, 24);
Serial.print("Transmitting to ");
Serial.println(text);
Udp.beginPacket(remoteIP, remotePort); // transmit datagram
Udp.print(text);
Udp.endPacket();
// if there's data available, read a packet
int packetSize = Udp.parsePacket();
if (packetSize) {
Serial.print("Received packet of size ");
Serial.println(packetSize);
Serial.print("From ");
displayIPaddress(Udp.remoteIP(), Udp.remotePort());
// read the packet into packetBuffer
char packetBuffer[100] = { 0 }; // buffer to hold incoming packet,
Udp.read(packetBuffer, packetSize); //UDP_TX_PACKET_MAX_SIZE); // receive datagram
Serial.print("Contents: ");
Serial.println(packetBuffer);
// if (strcmp(packetBuffer, "OK") != 0) {
// send a reply to the IP address and port that sent us the packet we received
// Udp.beginPacket(Udp.remoteIP(), Udp.remotePort());
// Udp.write("OK");
// Udp.endPacket();
delay(10);
// read IP address from keyboard and check it
IPAddress getIPaddress(const char* prompt) {
IPAddress ip;
while (1) { // read IP (end with new line)
Serial.print(prompt);
while (Serial.available() == 0) delay(10);
char text[40] = { 0 };
Serial.readBytesUntil('\n', (char*)text, 40);
//Serial.println(text);
if (ip.fromString(text)) break; // if IP OK break while
Serial.println("\ninvalid IP try again");
return ip;
// print IPAdress and port
void displayIPaddress(const IPAddress address, unsigned int port) {
Serial.print(" IP ");
for (int i = 0; i < 4; i++) {
Serial.print(address[i], DEC);
if (i < 3) Serial.print(".");
Serial.print(" port ");
Serial.println(port);
void displayMACaddress(byte address[]) {
Serial.print("MAC address ");
for (int i = 0; i < 6; i++) {
Serial.print("0x");
Serial.print(address[i], HEX);
if (i < 5) Serial.print(".");
and this Java UDPchat program on a PC
// UDPchat.java - simple peer-to-peer chat program using UDP
// - given remote IP address can send strings using UDP datagrams
// - will also wait for datagrams and display contents
// remote IP and port are specified via command line - default IP is 127.0.0.1 (i.e. localhost) and port is 1000
// e.g. to send datagrams to IP 146.227.59.130 port 1006
// java chat 146.227.59.130 1006
import java.io.*;
import java.util.*;
import java.net.*;
public class UDPchat extends Thread
private final static BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
int port=10000;//999;//10001;// 100006 // port to send/receive datagrams on
String remoteIPaddress= "192.168.1.176";//"169.254.144.20";//("192.168.1.8");//127.0.0.1"); // IP to send datagrams
// constructor, parameter is command line parameters
public UDPchat(String args[]) throws Exception
// get remote IP address and port from command line parameters
if (args.length > 0) remoteIPaddress = (args[0]); // get IPaddress
if (args.length > 1) port = Integer.parseInt(args[1]); // get port number
System.out.println("chat program: IP address " + InetAddress.getLocalHost().toString() + " port " + port );
start(); // start thread to receive and display datagrams
// loop waiting for keyboard input, send datagram to remote IP
while(true)
try
String s = in.readLine(); // read a String
System.out.println("Sending to " + remoteIPaddress + " socket " + port + " data: " + s);
byte[] data = s.getBytes(); // convert to byte array
DatagramSocket theSocket = new DatagramSocket(); // create datagram socket and the datagram
DatagramPacket theOutput = new DatagramPacket(data, data.length, InetAddress.getByName(remoteIPaddress), port);
theSocket.send(theOutput); // and send the datagram
catch (Exception e) {System.out.println("Eroor sending datagram " + e);}
// thread run method, receives datagram and display contents as a string
public void run()
try
// open DatagramSocket to receive
DatagramSocket ds = new DatagramSocket(port);
// loop forever reading datagrams from the DatagramSocket
while (true)
byte[] buffer = new byte[65507]; // array to put datagrams in
DatagramPacket dp = new DatagramPacket(buffer, buffer.length); // DatagramPacket to hold the datagram
ds.receive(dp); // wait for next datagram
String s = new String(dp.getData(),0,dp.getLength()); // get contenets as a String
System.out.println("UDP datagram length " + s.length()+ " from IP " + dp.getAddress() + " received: " + s );
catch (SocketException se) {System.err.println("chat error " + se); }
catch (IOException se) {System.err.println("chat error " + se);}
System.exit(1); // exit on error
public static void main(String args[]) throws Exception
UDPchat c=new UDPchat(args);
the PC displays
F:\UDPchat>javac UDPchat.java
F:\UDPchat>java UDPchat
chat program: IP address BB-DELL2/192.168.1.68 port 10000
UDP datagram length 15 from IP /192.168.1.176 received: hello from nano
UDP datagram length 16 from IP /192.168.1.176 received: test 2 from nano
heloo from Pc
Sending to 192.168.1.176 socket 10000 data: heloo from Pc
test2 from pc 1234567890
Sending to 192.168.1.176 socket 10000 data: test2 from pc 1234567890
UDP datagram length 24 from IP /192.168.1.176 received: test3 from nano 12345678
UDP datagram length 2 from IP /192.168.1.176 received: 90
and the Nano displays
11:52:38.636 -> Ethernet UDP chat program
11:52:38.636 ->
11:57:57.047 -> enter local IP address (e.g. 192.168.1.176)?
11:58:22.439 -> Remote MAC address 0xDE.0xAD.0xBE.0xEF.0xFE.0xB0
11:58:22.503 -> Ethernet cable is not connected.
11:58:22.503 -> Ethernet UDP started IP 192.168.1.176 port 10000
11:58:22.503 ->
11:58:22.503 -> enter remote IP address (e.g. 192.168.1.176)?
11:58:47.769 -> Remote IP 192.168.1.68 port 10000
11:58:58.364 -> Transmitting to IP 192.168.1.68 port 10000
11:58:58.398 -> hello from nano
11:59:11.072 -> Transmitting to IP 192.168.1.68 port 10000
11:59:11.072 -> test 2 from nano
11:59:28.712 -> Received packet of size 13
11:59:28.712 -> From IP 192.168.1.68 port 62709
11:59:28.746 -> Contents: heloo from Pc
11:59:42.652 -> Received packet of size 24
11:59:42.652 -> From IP 192.168.1.68 port 64535
11:59:42.652 -> Contents: test2 from pc 1234567890
11:59:56.328 -> Transmitting to IP 192.168.1.68 port 10000
11:59:56.328 -> test3 from nano 12345678
11:59:57.334 -> Transmitting to IP 192.168.1.68 port 10000
11:59:57.334 -> 90
