Bwanna
1
SETUP:
- IDE Arduino v2.0.0
- TFT_eSPI library version 2.4.76
- Board package version (don't know how to find this info - get from espressif)
- ESP32-WROOM-32D DevKitC
- TFT driver ST7789
- Interface SPI
ISSUE:
-Unable to change DC and RST GPIO assignments
DESC:
- Changes to the User_Setup.H don't work for DC & RST ONLY. (Changes to other GPIOs are applied correctly)
- Assignments in the sketch don't work either.
TFT_eSPI "User_Setup.h" configuration trying to be used:
#define TFT_MISO 19
#define TFT_MOSI 23
#define TFT_SCLK 18
#define TFT_CS 15 // Chip select control pin
#define TFT_DC 2 // Data Command control pin
#define TFT_RST 4 // Reset pin (could connect to RST pin)
//#define TFT_RST -1 // Set TFT_RST to -1 if display RESET is connected to ESP32 board RST
TESTING OUTPUT:
(from Read_User_Setup.ino)
TFT_eSPI ver = 2.4.72
Processor = ESP32
Frequency = 240MHz
Transactions = Yes
Interface = SPI
Display driver = 7789
Display width = 240
Display height = 320
MOSI = GPIO 23
MISO = GPIO 19
SCK = GPIO 18
TFT_CS = GPIO 15
TFT_DC = GPIO 0
TFT_RST = GPIO 2
Font GLCD loaded
Font 2 loaded
Font 4 loaded
Font 6 loaded
Font 7 loaded
Font 8 loaded
Smooth font enabled
Display SPI frequency = 27.00
Additional:
The display does work correctly using GitHub - adafruit/Adafruit-ST7735-Library: This is a library for the Adafruit 1.8" SPI display http://www.adafruit.com/products/358 and http://www.adafruit.com/products/618 with the same pin assignments
What do you mean by "can't change DC and RST GPIO pin assignments"?
GPIO_NUM_2 is typically the built in LED pin and can cause issues with some devices needing a clean signal.
#include <Adafruit_GFX.h> // Core graphics library
#include <Adafruit_ST7789.h> // Hardware-specific library for ST7789
//Adafruit_ST7789 tft = Adafruit_ST7789( TFT_CS , TFT_DC , TFT_MOSI , TFT_SCLK , TFT_RST );
Adafruit_ST7789 tft = Adafruit_ST7789( GPIO_NUM_15, GPIO_NUM_0, GPIO_NUM_13, GPIO_NUM_14, GPIO_NUM_22 );
void fDoTheDisplayThing( void * parameter )
tft.init( 240, 320 ); // Init ST7789 320x240
tft.setRotation( 3 );
tft.setTextSize( 3 );
tft.fillScreen( ST77XX_BLACK );
tft.setTextWrap( false );
struct stu_eData px_eData;
int OneTwoThree = 0;
int countUpDown = 255;
ledcWrite( 4, countUpDown ); //backlight set
int dimDelaytime = 7;
for (;;)
if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
xSemaphoreTake( sema_ScreenUpdate, portMAX_DELAY );
if (!BlankScreen)
for ( countUpDown; countUpDown-- > 0; )
ledcWrite( 4, countUpDown ); // write to channel number 4, dim backlight
vTaskDelay( dimDelaytime );
tft.fillScreen(ST77XX_BLACK);
tft.setCursor( 0, 0 );
OneTwoThree++;
if ( OneTwoThree == 1 )
tft.setTextColor( ST77XX_RED );
if ( OneTwoThree == 2 )
tft.setTextColor( ST77XX_WHITE );
if ( OneTwoThree == 3 )
tft.setTextColor( ST77XX_BLUE );
OneTwoThree = 0;
tft.println( "Temp " + String(px_eData.Temperature) + "F" );
tft.setCursor( 0, 30 );
tft.println( "Hum " + String(px_eData.Humidity) + "%" );
tft.setCursor( 0, 60 );
tft.println( "Pres " + String(px_eData.Pressure) + "mmHg" );
tft.setCursor( 0, 90 );
tft.println( "AQI " + String(px_eData.IAQ) + "%" );
tft.setCursor( 0, 120 );
tft.println( "RM0 " + String(px_eData.RM0) + "%" );
tft.setCursor( 0, 150 );
tft.println( "PM2 " + String(px_eData.PM2) + "ug/m3" );
tft.setCursor( 0, 180 );
tft.println( String(px_eData.WSV) + "V " + String(int(px_eData.WSC * 1000.0f)) + "mA " + String((int(px_eData.WSP * 1000.0f))) + "mW" );
//brighten blacklight level
vTaskDelay( 400 ); // wait for screen update to be done
if ( !BlankScreen )
for ( countUpDown; countUpDown <= 255; countUpDown++ )
//log_i( "DoTheBME280Thing high watermark % d", uxTaskGetStackHighWaterMark( NULL ) );
} //if ( xQueueReceive(xQ_eData, &px_eData, portMAX_DELAY) == pdTRUE )
xSemaphoreGive( sema_ScreenUpdate );
} //for (;;)
vTaskDelete( NULL );
} //void fDoTheDisplayTHing( void * parameter )
void fScreenBlanking( void *pvParameters )
int TimeOfPause = 10000 * 1000;
uint64_t PauseStartTime = esp_timer_get_time();
bool Pause = false;
for ( ;; )
if (!Pause )
//if motion detect then show display otherwise blank display
if ( !(gpio_get_level( GPIO_NUM_27)) )
BlankScreen = true;
vTaskDelay( 7 );
Pause = true;
ledcWrite( 4, 255 );
BlankScreen = false;
countUpDown = 255;
// still detecting movement reset blanking pause time
if ( gpio_get_level( GPIO_NUM_27) )
PauseStartTime = esp_timer_get_time(); // extend pause blanking time
if ( (esp_timer_get_time() - PauseStartTime) >= TimeOfPause )
Pause = false;
vTaskDelay( 250 );
} //void fScreenBlanking( void *pvParameters )
Is how I do the thing with an ESP32.
Bwanna
3
First, thank you for responding.
I don't have any problems using the Adafruit_ST7789.h setup. Both the DC & RST can be assigned to GPIO2 & GPIO4, respectively.
The problem is with the TFT_eSPI setup and GPIO configuration.
Trying to assign the following:
DC to GPIO2
RST to GPIO4
No matter what I set either in the User_Setup.h file or directly in the sketch, the outcome is always:
DC = GPIO 0
RST = GPIO 2
I hope that helps.
system
Closed
4
