Can't clean String?
I have two Strings with reserved memory to handle incoming data from serial. However, after I clean the content of the first one, it shows an extra blank line. Seems it has some end marker or something left and I was not able to clean it. Or the serial buffer has something in it which hold a place but doesn't trigger serial.availalbe().
My code:
String comdata = "";
String bufferS = "";
  comdata.reserve(60);
  bufferS.reserve(60);
  if (Serial.available())
    bufferS += char(Serial.read());
    Serial.println("bufferS");
    Serial.println(bufferS);
    if (bufferS.indexOf(",") != -1) {
      comdata = bufferS.substring(0, bufferS.length() - 1);
      bufferS = "";
    Serial.println("comdata");
    Serial.println(comdata);
after running it handles the very first input well: after I type "abc,", it shows :
bufferS
a
comdata
bufferS
ab
comdata
bufferS
abc
comdata
bufferS
abc,
comdata
abc
bufferS
comdata
abc
BUT NOTE THE BLANK LINES AFTER THE LAST bufferS.
Then I typed "123,", and it shows:
bufferS
1
comdata
abc
bufferS
12
comdata
abc
bufferS
123
comdata
abc
bufferS
123,
comdata
123
bufferS
comdata
123
Please follow the advice on posting code given in posting code
In particular note the advice to Auto format code in the IDE and to use code tags when posting code here as it prevents some combinations of characters in code being interpreted as HTML commands such as italics, bold or a smiley character, all of which render the code useless
UKHeliBob:
I have tried that, but mine browser might have some issue with that, so I don't see any buttons with that tag. So it is possible to manually add? Like < code/> or </> code </>?
Type [­code] before the code and [­/code] after it or use Copy for Forum from a right click in the IDE and paste into the forum editor complete with code tags
Turn off line ending in the Serial Monitor :wink:
septillion:
oh no....
