Cant combine geophone project with LoRa project
I am new to programming and I am trying to combine two sets of code (heltec LoRa esp32 OLED sender example, and an Adafruit ADS1115 amplifier comparator example. I have a geophone connected to a Gikfun 20A Range Current Sensor, which is connected to the ADS115, and that finally connects to the Heltec ESP32 LoRa OLED (I know its alot). Separately these codes work just fine. If I only upload the comparator project, the serial monitor reads the stimuli correctly. When I only upload the sender example the LoRa board properly communicates with my other heltec LoRa esp32 OLED reciever setup. But when I try to combine the two the serial monitor and serial plotter stop functioning. I am trying to have the LoRa module send a packet only if the Geophone detects vibration. Here are is the code below. Any suggestions? I've been stuck for 2 weeks
#include "heltec.h"
#include "images.h"
#define BAND    915E6  //you can set band here directly,e.g. 868E6,915E6
#include <Adafruit_ADS1X15.h>
// Adafruit_ADS1115 ads;  /* Use this for the 16-bit version */
Adafruit_ADS1115 ads;     /* Use this for the 12-bit version */
unsigned int counter = 0;
String rssi = "RSSI --";
String packSize = "--";
String packet ;
int ledPin = 13 //using pin 13 to blink the LED when the geophone is tapped
void logo()
  Heltec.display->clear();
  Heltec.display->drawXbm(0, 5, logo_width, logo_height, logo_bits);
  Heltec.display->display();
void flash() {
  digitalWrite(ledPin, HIGH);
  delay(100);
  digitalWrite(ledPin, LOW);
void message()
  Heltec.display->setTextAlignment(TEXT_ALIGN_LEFT);
  Heltec.display->setFont(ArialMT_Plain_10);
  Heltec.display->drawString(0, 0, "Sending packet: ");
  Heltec.display->drawString(90, 0, String(counter));
  // send packet
  LoRa.beginPacket();
     LoRa.setTxPower(txPower,RFOUT_pin);
     txPower -- 0 ~ 20
     RFOUT_pin could be RF_PACONFIG_PASELECT_PABOOST or RF_PACONFIG_PASELECT_RFO
       - RF_PACONFIG_PASELECT_PABOOST -- LoRa single output via PABOOST, maximum output 20dBm
       - RF_PACONFIG_PASELECT_RFO     -- LoRa single output via RFO_HF / RFO_LF, maximum output 14dBm
  LoRa.setTxPower(14, RF_PACONFIG_PASELECT_PABOOST);
  LoRa.print("hello ");
  LoRa.print(counter);
  LoRa.endPacket();
  counter++;
  digitalWrite(LED, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1000);                       // wait for a second
  digitalWrite(LED, LOW);    // turn the LED off by making the voltage LOW
void setup(void)
  Serial.println("Hello!");
  Serial.println("Single-ended readings from AIN0 with >3.0V comparator");
  Serial.println("ADC Range: +/- 6.144V (1 bit = 3mV/ADS1015, 0.1875mV/ADS1115)");
  Serial.println("Comparator Threshold: 1000 (3.000V)");
  // The ADC input range (or gain) can be changed via the following
  // functions, but be careful never to exceed VDD +0.3V max, or to
  // exceed the upper and lower limits if you adjust the input range!
  // Setting these values incorrectly may destroy your ADC!
  //        ADS1015  ADS1115
  // ads.setGain(GAIN_TWOTHIRDS);  // 2/3x gain +/- 6.144V  1 bit = 3mV      0.1875mV (default)
  // ads.setGain(GAIN_ONE);        // 1x gain   +/- 4.096V  1 bit = 2mV      0.125mV
  // ads.setGain(GAIN_TWO);        // 2x gain   +/- 2.048V  1 bit = 1mV      0.0625mV
  // ads.setGain(GAIN_FOUR);       // 4x gain   +/- 1.024V  1 bit = 0.5mV    0.03125mV
  // ads.setGain(GAIN_EIGHT);      // 8x gain   +/- 0.512V  1 bit = 0.25mV   0.015625mV
  // ads.setGain(GAIN_SIXTEEN);    // 16x gain  +/- 0.256V  1 bit = 0.125mV  0.0078125mV
  if (!ads.begin()) {
    Serial.println("Failed to initialize ADS.");
    while (1);
  // Setup 3V comparator on channel 0
  ads.startComparator_SingleEnded(0, 1000);
  //WIFI Kit series V1 not support Vext control
  Heltec.begin(true /*DisplayEnable Enable*/, true /*Heltec.Heltec.Heltec.LoRa Disable*/, true /*Serial Enable*/, true /*PABOOST Enable*/, BAND /*long BAND*/);
  Heltec.display->init();
  Heltec.display->flipScreenVertically();
  logo();
  delay(1500);
  Heltec.display->drawString(0, 0, "Heltec.LoRa Initial success!");
  int adc0;
  // Comparator will only de-assert after a read
  adc0 = ads.getLastConversionResults();
  Serial.print("AIN0: "); Serial.println(adc0);
  if (adc0 > 0 ) {
    flash();
    message();
  } else if (adc0 < -1 ) {
    flash();
    message();
  delay(100);
What level is your understanding of the operation of each sketch, individually? What was your strategy or approach for the merge? Can you not post the original sketches, or link to them if they are static examples? Are there long do-nothing delays in either sketch?
My level of understanding is pretty basic but I've been experimenting with both projects separately. I got the two LoRa esp32 to send data packets to the other using the example project listed below
  This is a simple example show the Heltec.LoRa sended data in OLED.
  The onboard OLED display is SSD1306 driver and I2C interface. In order to make the
  OLED correctly operation, you should output a high-low-high(1-0-1) signal by soft-
  ware to OLED's reset pin, the low-level signal at least 5ms.
  OLED pins to ESP32 GPIOs via this connecthin:
  OLED_SDA -- GPIO4
  OLED_SCL -- GPIO15
  OLED_RST -- GPIO16
  by Aaron.Lee from HelTec AutoMation, ChengDu, China
  成都惠利特自动化科技有限公司
  https://heltec.org
  this project also realess in GitHub:
  https://github.com/Heltec-Aaron-Lee/WiFi_Kit_series
#include "heltec.h"
#include "images.h"
#define BAND    868E6  //you can set band here directly,e.g. 868E6,915E6
String packet ;
void logo()
  Heltec.display->drawXbm(0,5,logo_width,logo_height,logo_bits);
  logo();
  delay(1500);
  // send packet
  LoRa.beginPacket();
 * LoRa.setTxPower(txPower,RFOUT_pin);
 * txPower -- 0 ~ 20
 * RFOUT_pin could be RF_PACONFIG_PASELECT_PABOOST or RF_PACONFIG_PASELECT_RFO
 *   - RF_PACONFIG_PASELECT_PABOOST -- LoRa single output via PABOOST, maximum output 20dBm
 *   - RF_PACONFIG_PASELECT_RFO     -- LoRa single output via RFO_HF / RFO_LF, maximum output 14dBm
  LoRa.setTxPower(14,RF_PACONFIG_PASELECT_PABOOST);
  LoRa.endPacket();
  counter++;
I have also managed to get the Geophone to function properly using the same micro controller (Heltec esp32 LoRa). Im using an amplifier for a better analog input for the geophone and even attached a small LED to give my phyiscal feedback of the project along side the serial monitor and serial plotter. the code i used is listed below
void flash() {
  delay(100);
void setup(void)
  //        ADS1015  ADS1115
  if (!ads.begin()) {
    while (1);
  int adc0;
  if (adc0 > 0 ) {
    flash();
    flash();
  delay(100);
I only have one delay in the program at the end, and its only a 10th of a second.
That is more than enough to crash a lot of programs. You need to investigate. One way would be to add a 100ms delay to the sketch that doesn't currently have it, and see if it still works.
You didn't say which program the delay was inherited from...
What about this? It's 2000 ms.
ahh i didnt even realize i copied that into my combined project. I'll remove the delays and give it a try again.
So I got rid of the delays except for the 100 ms one at the end of the program and the serial monitor is working again but it's crashing. Do you think it would be better to use millis() instead of delays?
new formatted code below.
#include "heltec.h"
#include "images.h"
Adafruit_ADS1015 ads;     /* Use this for the 12-bit version */
// these constants won't change:
int16_t geophone = 36; // the piezo is connected to analog pin 0
int threshold1 = 0;  // threshold value to decide when the detected sound is a knock or not
int threshold2 = -1;  // threshold value to decide when the detected sound is a knock or not
// these variables will change:
int sensorReading = 0;      // variable to store the value read from the sensor pin
String packet ;
void GEOsetup(void)
  //        ADS1015  ADS1115
  if (!ads.begin()) {
    while (1);
void logo()
  GEOsetup();
  Serial.begin(9600);       // use the serial port
  logo();
  // read the sensor and store it in the variable sensorReading:
  geophone = ads.getLastConversionResults();
  sensorReading = (geophone);
  Serial.print("GEOPHONE: "); Serial.println(geophone);
  // if the sensor reading is greater than the threshold:
  if (geophone > threshold1) {
  // send packet
  LoRa.beginPacket();
 * txPower -- 0 ~ 20
  LoRa.endPacket();
  counter++;
    // send the string "Knock!" back to the computer, followed by newline
    Serial.print("--Knock!"); Serial.println(geophone);
    if (geophone < threshold2) {
  // send packet
  LoRa.beginPacket();
 * txPower -- 0 ~ 20
  LoRa.print("Stimulant: ");
  LoRa.endPacket();
  counter++;
  delay(100);  // delay to avoid overloading the serial port buffer
this is what I am getting now in my serial monitor.
You need to be more meticulous about repetition. There are two Serial.begin() statements. That in itself might get swept under the rug, but it's a sign that the sketches haven't been closely compared.
